Old 03-29-2006, 09:37   #1 (permalink)
Member: 43873
Thanks Meter: 3
6620 second boot error
help i have here a 6620 first boot ok second boot error what could be the solution thanks in advance...
Old 03-29-2006, 09:51   #2 (permalink)
Member: 249504
Thanks Meter: 2
probably the problem is in your flashes. hot them and try again
Old 03-29-2006, 10:23   #3 (permalink)
Member: 251327
Thanks Meter: 8
this problem can not flash. you must change upp. Evrencell you dont learn yet. i am teach you this.
Old 03-29-2006, 10:42   #4 (permalink)
..::My3gtech::..'s Avatar
Member: 158032
Thanks Meter: 331
Hi guy's in this case first rehot the flash Ic's i hope it will be ok if not then change the flash Ic's and then reflash it again and all is ok.
Omairbutt786
Old 03-29-2006, 11:11   #5 (permalink)
Member: 249504
Thanks Meter: 2
if my friend jpscomm posts the result here, you will see the problem where is.. upp or flash. if problem is from upp, you didnt teach me sufficiently. but if the problem is from flashes, it means that "horn passed hear" in a famous turkish idiom my dear teacher
Old 03-29-2006, 11:36   #6 (permalink)
Member: 43873
Thanks Meter: 3
by the way the phone is water damaged the upp version is read by prodigy box but the secondary boot cannot be opened.
Old 03-29-2006, 11:43   #7 (permalink)
Member: 251327
Thanks Meter: 8
kesin diye birşey yokk önce işlemci son ihtimal flash dan olur sökküp takmak yeterli olur işlemciyi
Old 03-29-2006, 11:53   #8 (permalink)
Member: 43873
Thanks Meter: 3
by the way does anyone have service manual fornokia 6620?there might be cut lines i couldnt find one thanks...
Old 03-29-2006, 18:45   #9 (permalink)
petermov's Avatar
Member: 79485
Thanks Meter: 47
yep
is UPP problem, no way to dubt.
Old 03-29-2006, 18:50   #10 (permalink)
petermov's Avatar
Member: 79485
Thanks Meter: 47
and...
if you see carefully, prodigy gives you a different value each time is read "upp id" that means the UPP i.c is damaged.
Old 03-29-2006, 22:43   #11 (permalink)
Member: 43873
Thanks Meter: 3
ok thanks try to change upp first and then i'll post the results here
Old 03-29-2006, 23:18   #12 (permalink)
petermov's Avatar
Member: 79485
Thanks Meter: 47
mmm.
try to clean and dry the board, then reflow upp, in many cases this is enough.
Old 04-02-2006, 20:56   #13 (permalink)
Member: 43873
Thanks Meter: 3
by the way if i damaged the upp can i replace it with any dct4 upp? it looks like dct4 upp and not wd2 upp? thanks...
Old 04-03-2006, 11:13   #14 (permalink)
petermov's Avatar
Member: 79485
Thanks Meter: 47
mmm...
may be you can replace, only thing to see is the revision of upp (2.0, 2.5 or 3.0) it is on the top of the chip, replace for another dct4 is not the best solution cause many times i.c. is damaged on the removing process.
Old 04-03-2006, 15:10   #15 (permalink)
Member: 43873
Thanks Meter: 3
i seldom damage the upp whenever i remove one but if this upp is damaged it might not turn on if i put it back the upp body no. is v 835 4373019 i'll try to rework the upp first before replacing it's hard to buy upp here in our country... thanks for the info...
6600 White Screen-first Boot Ok-second Boot Error 2-help zone2 Nokia Hardware & Hardware Repair 2 11-14-2007 16:52
6600 second boot error kdawood WD2 & APE (Symbian Phones) 9 08-26-2007 00:31
6230i second boot error 6.. sergo_zmeia Nokia Hardware & Hardware Repair 4 06-28-2006 09:21
Nokia 3220 second boot error fedjak Twisterflasher 3 12-29-2005 17:50
6600 sending second boot loader ... Byte Nokia Hardware & Hardware Repair 10 02-11-2005 11:03
Page generated in 0.43861 seconds with 8 queries
