Old 03-28-2007, 21:21   #1 (permalink)
Member: 240930
Thanks Meter: 16
Arrow 6630 charge view but no charging !!
I have a 6630 and it charge view but no charging
i changed tahvo ic but it have same problem
then i changed battery and charger but not changed!!!
what is problem?
The Following User Says Thank You to majidjony For This Useful Post:
Old 03-29-2007, 04:19   #2 (permalink)
Member: 219201
Thanks Meter: 11
just change thayo charging ic test solution br
The Following User Says Thank You to karancomm For This Useful Post:
Old 03-29-2007, 04:39   #3 (permalink)
Member: 219201
Thanks Meter: 11
change retu along with it
Old 03-29-2007, 05:23   #4 (permalink)
jaggi's Avatar
Member: 258480
Thanks Meter: 14
try this...............
The Following User Says Thank You to jaggi For This Useful Post:
Old 03-29-2007, 05:53   #5 (permalink)
Member: 388374
Thanks Meter: 49
The Following User Says Thank You to Jintana For This Useful Post:
Old 03-29-2007, 12:02   #6 (permalink)
Member: 190856
Thanks Meter: 27
check any coil if shot change coil ur problom solve 100%
The Following User Says Thank You to gameland For This Useful Post:
Old 03-29-2007, 14:48   #7 (permalink)
Member: 240930
Thanks Meter: 16
i xhanged iretu but co changed it can be charge but battery cannot in, have show charging at phone running, but when u plug out still low battery or empty, any body have this solution?
Old 03-30-2007, 17:24   #8 (permalink)
Member: 240930
Thanks Meter: 16
I changed tahavo by a new ic and i successed .i befor replaced by another phones.
Thanks for your guides
Old 04-02-2007, 14:16   #9 (permalink)
Member: 148957
Wink
Originally Posted by Jintana View Post
thanks for ur interst
The Following User Says Thank You to nadora351430 For This Useful Post:
Old 04-02-2007, 16:15   #10 (permalink)
mhamad-198's Avatar
Member: 437340
Thanks Meter: 35
change ic thavo good work charging......
The Following User Says Thank You to mhamad-198 For This Useful Post:
6600 charge show but no charge Deb Chandan Nokia Hardware & Hardware Repair 6 10-05-2009 18:39
E90, charge ok but no charge in battery.??? blaiseid Nokia Hardware & Hardware Repair 3 04-04-2009 10:44
Z530 view charging but no charge realy...!!! majidjony Sony Ericsson Hardware Repair 5 11-27-2008 21:05
6630 charg ok but no power on mory2 Nokia Base Band 5 ( BB-5 ) 1 12-02-2005 23:25
Motorola V3688 show charging but no charging...Any ideea??? xchris Motorola Hardware Repair 2 10-26-2002 14:52
Page generated in 0.35894 seconds with 9 queries
