03-15-2006, 14:08 | #3 (permalink) |
No Life Poster Join Date: Apr 2004 Age: 49
Member: 61294 Status: Offline Thanks Meter: 49 | well, i have some little that can help you. 1. powering on your phone !!!! 2.battery is the most important part of the phone performed to do duties. 3.power on supply modules on phone such as ic's and cpu units. 4.PCB unit is important to know. 5.on/off key is there. 6.back - up battery inside the phone. 7.battery tips for battery connector to flow current in to the phone. 8.flash Rom in the phone board. 9.cpu is important , all area around the cpu , the pins attachments to the cpu unit. 10. Ram of the phone !!!! 11.the clock amplifier to your phone. common error to your phone . 1.wrong flashing files. 2.wrong application tricks to phone. 3.overcharging battery to phone . 4.wrong charger to your phone can check this problem. 5.power ic's unit can be unsoldered well , after poor use of phone. 6.contact with water . bestman |
03-15-2006, 14:19 | #4 (permalink) | |
Freak Poster Join Date: Feb 2006
Member: 234955 Status: Offline Thanks Meter: 19 | Quote:
try also flashing your phone using MCU C2 file | |
6670 dead | Triminity | Nokia Hardware & Hardware Repair | 5 | 08-25-2006 20:33 |
6670 dead | .:::Dr. Cell:::. | WD2 & APE (Symbian Phones) | 7 | 03-04-2006 15:37 |
6670 dead flashing with jaf Plz help | Mobile Master Pk | WD2 & APE (Symbian Phones) | 0 | 01-29-2006 19:27 |
