12-22-2005, 11:41 | #1 (permalink) |
No Life Poster Join Date: Dec 2002 Location: nigeria
Member: 18926 Status: Offline Sonork: ndagi Thanks Meter: 52 | 6681 power switch?? got this 6681 today, it charges okay and comes on when connected to twister @ read info but would not power on with battery.looking for a repair manual of this phone or any solution from u guys. thanks in advance regards ndagi |
12-26-2005, 20:29 | #2 (permalink) |
Junior Member Join Date: Nov 2005
Member: 202155 Status: Offline Thanks Meter: 0 | few solutions First, i would try to clear contacts on which comes batery, and contacts on board( also the ones where is batery ).That would be my first step, after that you should check your batery( if it is older then 1 year or year and half,it could have low capacity) it maybe has voltage, but capacity is the key, with low capacity it will not power on,also if it is under some voltage( less then 3 volts) in some cases it will not charge, ,and it will not power on, if this things are ok then you need to rehoot some of the chips. Ic and some others. Hope that i helped. |
12-26-2005, 20:53 | #3 (permalink) |
Member: 202155 Status: Offline Thanks Meter: 0 | Also very important When you use heater for anything around processor, you need to cover it ( cover processor with metal closed case) , to not get over heated. Just be careful when heating around it. |
12-26-2005, 21:45 | #4 (permalink) |
Member: 18926 Status: Offline Sonork: ndagi Thanks Meter: 52 | done all of that already friend! right now the service manual and or repair manual is what i'll need to attempt to isolate the problem. regards ndagi |
6681 Dead, Switches On Only When JAf Connected | andyvikas | Nokia Hardware & Hardware Repair | 1 | 05-20-2007 18:46 |
3310,8210 Power switch solution. 6610 volume switch solution(NEED HELP) | smartfone | Nokia Hardware & Hardware Repair | 7 | 09-15-2006 06:29 |
3200 power switch, new switch? | sjakie | Nokia Hardware & Hardware Repair | 5 | 02-14-2006 22:58 |
