08-18-2005, 06:23 | #1 (permalink) |
No Life Poster Join Date: Oct 2003 Location: MUMBAI Age: 53
Member: 41672 Status: Offline Thanks Meter: 195 | 6670 phone start up failed contact the retailer thanks shri Last edited by TechPhone; 08-18-2005 at 06:35. |
08-18-2005, 10:09 | #3 (permalink) | |
Freak Poster Join Date: Jul 2003
Member: 34310 Status: Offline Thanks Meter: 23 | Quote:
This is same problem with 7610. U can use search button to find for this solution! B.R Vinh Hai | |
08-21-2005, 22:49 | #6 (permalink) |
Member: 41672 Status: Offline Thanks Meter: 195 | 6670 phone start-up failed. contect retailer flashing so many times with Dctx_UFS_1.3k & try to full erase & after flashing pm writing, unlock Set UI Factory Defaults Ok, Time: 00:07 Set Full Factory Defaults Ok, Time: 01:23 Set Software Upgrade Defaults Ok, Time: 00:00 Set Security Ok, Time: 00:00 IMEI: 355023-00-394320-9, ASIC: 5 SimLocks Initialized, Time: 00:12 all ok at last format user area done but same sowing contect retailer pls. help me. thanks |
08-22-2005, 03:12 | #8 (permalink) | |
Format by manualy: Power the phone off Press down talk(green) + 3 + * Power the phone on If u make correctly u will see "formatting..." And when format finish u can use ur phone normaly. B.R Vinh Hai Last edited by VinhHai; 08-22-2005 at 04:40. | |
The Following User Says Thank You to VinhHai For This Useful Post: |
10-24-2006, 15:14 | #12 (permalink) |
Junior Member Join Date: Oct 2005
Member: 193652 Status: Offline Thanks Meter: 0 | Ok I Will Give You The Right Solution For 7610 Contact Retailer ... You Must Format The Phone If It Did Not Whorking You Must Replace The Ram Black Or Som Time If You Heet The Flash It Whork |
10-25-2006, 03:00 | #13 (permalink) | |
Insane Poster Join Date: Sep 2004 Age: 50
Member: 83879 Status: Offline Thanks Meter: 4 | Quote:
put off both flashes,reball it, fix it again,format mannually. tested many times in 7610 6670. | |
10-26-2006, 05:09 | #15 (permalink) |
Freak Poster Join Date: Aug 2004 Location: The great pakistan
Member: 79823 Status: Offline Thanks Meter: 26 | well i think you should do the hold key way like hold *3and send key and power on that will solve the problem no need for flashing and any dam box |
N96 Phone Start-up failed Contact the retailer (security Test failed in reading) | dmaetrey | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 02-08-2010 13:46 |
7650 Phone start-up failed .Contact the retailer. Impossible with Prodigy??? | xbaert | Federal One | 11 | 04-23-2005 10:50 |
3650 Phone start-up failed .Contact the retailer | sunrise gsm | Griffin | 4 | 08-21-2004 11:38 |
phone start-up failed. Contact the retailer | Solutions13 | Nokia Digital Core Technology 4 ( DCT-4 ) | 0 | 11-13-2002 15:34 |
Phone start-up failed. Contact the retailer | kenichi | Nokia Digital Core Technology 4 ( DCT-4 ) | 5 | 10-08-2002 08:47 |
