04-20-2007, 17:40 | #1 (permalink) |
No Life Poster Join Date: Apr 2005 Age: 45
Member: 139388 Status: Offline Thanks Meter: 98 | 6670 very strange keypad problem needed help I reflowed the keypad ics and it is worked fine.But after 5 to 6hours again the same keys are not working.So i changed the both keypad ics result when we press the key 6 one time,6 or 7 times 6 number was typed on the display Then i again changed another keypad ic after that the key 6 is not working there after???? I checked also the keypad plate. 4 keypad ics also waste??? Where it will be the problem??? |
04-20-2007, 19:34 | #2 (permalink) |
Freak Poster Join Date: May 2006
Member: 278058 Status: Offline Thanks Meter: 81 | When u are sure that the keypad, keypad connector and the keypad IC's are OK, then before reheating the UPP take a look at the capacitor on the left of the UPP which are connected between UPP and keypad IC's. After that UPP is the only remaining reason for that problem. But before this, take again a look at those parts: keypad, connector and IC |
04-21-2007, 06:13 | #3 (permalink) | |
Member: 139388 Status: Offline Thanks Meter: 98 | Quote:
thk u for u r reply.Can u pls give me the picture for (capacitor on the left of the UPP which are connected between UPP and keypad IC's.) | |
Nokia 1112 Strange Keypad problem..Experts Help me. | rk_grover77 | Nokia Hardware & Hardware Repair | 16 | 06-27-2013 09:37 |
LG KS360 strange flashing problem-Need Help! | mobile-phone-service | VygisToolbox | 2 | 03-18-2009 22:08 |
N5300 strange camera problem,need help !!! | andest | Nokia Base Band 5 ( BB-5 ) | 2 | 11-01-2008 15:03 |
E710 Strange Display Problem ! Need Help | goanga | Samsung Hardware Repair | 8 | 10-18-2008 19:02 |
BB5 Box - Strange cable problems - Need help ! | GsmHgvnl | BB5BOX | 11 | 10-05-2007 23:32 |
