Old 01-24-2006, 17:46   #1 (permalink)
nofear197979's Avatar
Member: 68311
Thanks Meter: 34
6680 Camera Problim
look at this problim its funny
when i use 6680 offline without sim card the camera works
but when i use it online and with sim card the camera dont work
i maked flash with universal box and erase and nothing happened
any solution plz ????????????????????????????????
Old 01-24-2006, 19:00   #2 (permalink)
darkblues's Avatar
Member: 112788
Thanks Meter: 24
if u r sure of ur flashing issue , so its a hardware prob pal
i hadn't face this problem b4 but let us think about it 2gether
i think the problem is a power short
in offline mode phone disconnect the the sim card reader .. so its out of powering,
but in online mode sim card pins are pwoered on by the phone.. so as a result
of miss connecting a power shorting accured which is cause ur camera deactivating...
the problem may be with ur sim card magniticity (A WEEKPOSIBILITY ,.. BUT ITS THERE...) and u can check it very easyly by changing the sim card..
and if its not u have to clean the mean board .. test the sim ways..
thats my imagination about it..
plz any body correct me if iam wrong...
DARKBLUES
Old 01-24-2006, 23:14   #3 (permalink)
Member: 68311
Thanks Meter: 34
thanks sir for ur reaply and i will check what u said
Old 01-25-2006, 13:32   #4 (permalink)
darkblues's Avatar
Member: 112788
Thanks Meter: 24
its ok but plz post the results cuz we all need 2 learn something new..
Old 01-26-2006, 14:06   #5 (permalink)
Member: 68311
Thanks Meter: 34
All The Sim Pins Are Ok And Nothing Happened After I Cleaned The Board
Old 01-26-2006, 16:42   #6 (permalink)
darkblues's Avatar
Member: 112788
Thanks Meter: 24
try 2 get the chematic 4 the board and follow the tracks, i 'll try 2 find it 4 u..
i read u talked about flashing with universal box?? u mean ufs?? and u full erase it ??!! u cant erase bb5 phone.. try 2 flash it with any other box just like gti or try 2 flash it with any other v.. b4 u lose urself with hardware soltions..
'll tell u if ia have anything new and so u do
Old 02-09-2006, 13:20   #7 (permalink)
Registered User
Member: 195513
Thanks Meter: 67
iI have the same problem wi9th the nokia 6680,the camera will function in offline mode only but when i insert a sim the camera will not function well,it says camera not supported.it took me 2 weeks to solve the problem and i already solve it.THE SOLUTION IS................................................ .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. ..................................YOU MUST RESOLDER THE SIM HOLDER OF YOUR NOKIA 6680.THIS IS 100% TESTED.I HAVE JUST SOLVE THE PROBLEM TODAY FEBRUARRY 9,2006............................................ .................................................. .................................................. .................................................. ...............................................TEL L ME IF ITS OK.TELL ME IF ITS WORKING
Old 02-09-2006, 14:54   #8 (permalink)
darkblues's Avatar
Member: 112788
Thanks Meter: 24
i guess logicaly its a working solution...
but
1rst: u have 2 post a chematic or something by 4 what u did 2 make it clear
2nd : i guess that nofear have 2 try it also so we can make sure its a worjing solution by test it with 2 different cases
DARKBLUES
Old 02-23-2006, 12:23   #9 (permalink)
Member: 176776
Thanks Meter: 5
can you find a diagram to show us - this would really help
Old 02-23-2006, 15:33   #10 (permalink)
Member: 127269
Sonork: 100.1605945
Thanks Meter: 68
Can u plz try with jaf? do not forget to full factory set after flashing
Old 03-03-2006, 10:04   #11 (permalink)
vijaya7668's Avatar
Member: 143278
Thanks Meter: 26
i also got this problem........need clean which one ic??
Old 04-26-2006, 12:12   #12 (permalink)
kiriazy's Avatar
Member: 50456
well i cleaned the board well & i resoldered the sim connector & i also changged the som filter 7 times but still the same
any other ideas ??
kiriazy
Old 05-11-2006, 12:22   #13 (permalink)
Registered User
Member: 195513
Thanks Meter: 67
sorry but i cant post any picture.all u have to do is resolder the sim holder of your 6680.i have solve two cases with the same problem.
Old 05-11-2006, 12:25   #14 (permalink)
Registered User
Member: 195513
Thanks Meter: 67
hi!also try to resolder the sim reader of your 6680 and try to change the sim fiulter.
Old 09-16-2006, 11:19   #15 (permalink)
Member: 292887
any tested solution for this problem?????
k800i camera problim. nofear197979 Universalbox 6 08-05-2007 09:37
N93 camera problim. nofear197979 Nokia Base Band 5 ( BB-5 ) 6 03-28-2007 03:01
6680 charging problim hira152 Nokia Hardware & Hardware Repair 1 02-25-2007 14:51
6680 camera and bluetooth problim nofear197979 Nokia Base Band 5 ( BB-5 ) 9 07-02-2006 22:24
PDA camera problim nofear197979 HTC & PDA WM( With Touchscreen) 9 03-08-2006 14:01
Page generated in 0.26488 seconds with 10 queries
