Old 01-20-2007, 13:52   #1 (permalink)
Member: 372599
Thanks Meter: 41
6680 Charging. but not switching on.. Need Help.. pls..
hi.. i have got one Nokia 6680.. which is charging.. but not switchig on.. can anybody help me please.. that how to fix this phone.. ????? thanks
Old 01-20-2007, 15:18   #2 (permalink)
akkaamgopi's Avatar
Member: 247683
Thanks Meter: 49
change the on/off switch
Old 01-20-2007, 20:53   #3 (permalink)
.:KHALIFA:.'s Avatar
Member: 275631
Thanks Meter: 408
chek on off track....
Old 01-20-2007, 22:31   #4 (permalink)
abu osama's Avatar
Member: 103786
Thanks Meter: 81
chang ic light front ic keybad
Old 01-21-2007, 10:10   #5 (permalink)
capri's Avatar
Member: 396326
Thanks Meter: 229
No power but charging ok, solution
Maybe I can help you...
br
capri
Old 01-21-2007, 10:22   #6 (permalink)
Abussabah's Avatar
Member: 412813
Sonork: 100.1594692
Thanks Meter: 353
capri is right,do this solution ,if not ok check or rehot retuic
Old 01-22-2007, 08:06   #7 (permalink)
Member: 372599
Thanks Meter: 41
thanks guys.. i m going to try.. then i will post the result...
Old 01-22-2007, 08:14   #8 (permalink)
makkah mobile's Avatar
Member: 226363
Sonork: 03--4899925
Thanks Meter: 569
capri is rite just do that
Old 01-22-2007, 08:28   #9 (permalink)
rana_sab's Avatar
Member: 62911
Thanks Meter: 156
bakhshalvi007 there are small crystal ic near keypad connector ,
this is 6 point BGA ic
1 2 3
4 5 6
remove it make jumper 1 to4 and 3 to 6
Old 01-23-2007, 08:49   #10 (permalink)
Member: 372599
Thanks Meter: 41
Thanks Capri and Rana sahib.. i have done it..
Old 01-23-2007, 21:47   #11 (permalink)
Member: 217853
Thanks Meter: 13
n70 charging ok but not on any solution .
Old 01-24-2007, 00:31   #12 (permalink)
abu osama's Avatar
Member: 103786
Thanks Meter: 81
chang two ic lcd or right ic lcd
Old 01-24-2007, 22:36   #13 (permalink)
Member: 275631
Thanks Meter: 408
try this may b this can help
Old 01-25-2007, 08:51   #14 (permalink)
capri's Avatar
Member: 396326
Thanks Meter: 229
N70 Charging but not power on solution
br
capri
Old 02-04-2007, 14:35   #15 (permalink)
Satyam321's Avatar
Member: 269198
Thanks Meter: 78
it rights
try the solution they send you try this also
n70. charge, but not switch on escorpiao Nokia Hardware & Hardware Repair 9 10-11-2008 09:36
E50 charging but not switching on ..::Sunil::.. Nokia Hardware & Hardware Repair 1 08-03-2008 14:32
Nokia N 70 charging but not switch on Unlocker AL Nokia Hardware & Hardware Repair 7 06-24-2008 21:05
D820 cgarging but not switching On.. Need Help please bakhshalvi007 Samsung Hardware Repair 2 01-08-2007 15:12
T610 charging but not switch on samanthe Sony Ericsson Hardware Repair 5 06-02-2005 21:45
Page generated in 0.26715 seconds with 10 queries
