03-07-2006, 12:27 | #3 (permalink) | |
No Life Poster Join Date: Nov 2001 Age: 55
Member: 7363 Status: Offline Thanks Meter: 24 | Quote:
with ufs + original HWK all is very good flash and very speed try to flash with correct flash and with original HWK | |
03-15-2006, 12:01 | #4 (permalink) | |
Registered User Join Date: Jun 2004 Age: 46
Member: 68983 Status: Offline Thanks Meter: 55 | Quote:
you is a Tunisian milyarder | |
03-15-2006, 14:52 | #5 (permalink) |
No Life Poster Join Date: Apr 2004 Age: 49
Member: 61294 Status: Offline Thanks Meter: 49 | well, i have some little that can help you. 1. powering on your phone !!!! 2.battery is the most important part of the phone performed to do duties. 3.power on supply modules on phone such as ic's and cpu units. 4.PCB unit is important to know. 5.on/off key is there. 6.back - up battery inside the phone. 7.battery tips for battery connector to flow current in to the phone. 8.flash Rom in the phone board. 9.cpu is important , all area around the cpu , the pins attachments to the cpu unit. 10. Ram of the phone !!!! 11.the clock amplifier to your phone. common error to your phone . 1.wrong flashing files. 2.wrong application tricks to phone. 3.overcharging battery to phone . 4.wrong charger to your phone can check this problem. 5.power ic's unit can be unsoldered well , after poor use of phone. 6.contact with water . bestman |
6680 dead | skkeptik2 | Nokia Base Band 5 ( BB-5 ) | 2 | 08-30-2005 12:19 |
6680 Dead | nofear197979 | Phoenix Black Box | 2 | 07-12-2005 14:11 |
6680 Dead | nofear197979 | Phoenix Black Box | 0 | 07-12-2005 11:25 |
