11-10-2006, 13:12 | #1 (permalink) |
Junior Member Join Date: Nov 2006
Member: 388393 Status: Offline Thanks Meter: 0 | 6680 problem no network i'm really worried about my phone. is there an expert technician here???? pls help, what would be the problem of my 6680? i dont want to risk my ANTENNA SWITCH, and later to found out it was not the problem... pls help. or anybody here can refer me to a nice expert technician that could help by the way the symptoms of my phone were: it displays a fake signal, but sometimes on a right area and when the signal displays full it can do outgoing and incoming messages, but calls can only last to few seconds. prior to the incidence, i was using my phone on daily bases to surf the net, it took me 8-12 hrs. and sometimes non-stop, with charger connected when the batt is low, i also dropped it few times but in an estimated 2 feet high... so these was my daily routine with my 6680. i am asking, what would be the right action to be done by my technician to solve the problem and what should not be done to avoid further damage to my phone? is the antenna switch the right hardware to move? |
11-10-2006, 22:52 | #2 (permalink) |
Insane Poster Join Date: Sep 2004 Age: 50
Member: 83879 Status: Offline Thanks Meter: 4 | I repaired many 6630 & 6680 mobiles in network problem.Mostly fault is dryjoint of Hinku & Vinku (two rf ics).If he is a good technition than says him to put off both ics,reball them & fix them again. |
06-27-2007, 07:59 | #4 (permalink) | |
No Life Poster Join Date: May 2007 Location: GSM WORLD
Member: 510122 Status: Offline Sonork: 100.1606547 Thanks Meter: 1,822 | Quote:
plz menual serch and post me result like find network,no network asses many many amar181 [email protected] | |
06-27-2007, 12:32 | #5 (permalink) |
Freak Poster Join Date: Mar 2006
Member: 249213 Status: Offline Thanks Meter: 7 | my 6680 manual search result is only found GSM-900 & GSM-1900, can't get GSM-1800, then i tried to change new vinku & hinku already. but the problem still the same. please advice & help. |
07-01-2007, 16:49 | #8 (permalink) |
No Life Poster Join Date: Feb 2007 Location: Phnom Penh(CAMBODIA)
Member: 447590 Status: Offline Thanks Meter: 378 | U realy never get it?I posted so many soluotion with picture.Get it now & post result. |
The Following User Says Thank You to chandy pok For This Useful Post: |
11-15-2008, 08:07 | #15 (permalink) |
Junior Member Join Date: Nov 2008 Location: UK
Member: 893647 Status: Offline Thanks Meter: 0 | gurannted ur phone will work on bl-4c battery.not bl5c battery try this out iam using bl-4c battery in my phone from last fewq days after this problem showed up......the siganlas are working well |
1680c imei change problem no network | uzmantel | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 0 | 02-11-2010 12:04 |
2330c unlocking problem, NO NETWORK | crossroads | Cyclonebox | 13 | 09-17-2009 08:23 |
6680 help no network found | ece_05 | Nokia Hardware & Hardware Repair | 1 | 10-12-2008 17:09 |
Weirdo Z610 problem..No network on GSM | Hicky | Sony Ericsson Hardware Repair | 0 | 02-09-2008 08:49 |
Siemens St60 Problem, No Network | lakspur | Siemens Hardware Repair Area | 2 | 01-02-2006 09:25 |
