01-03-2006, 23:12 | #1 (permalink) |
No Life Poster Join Date: Apr 2002 Location: The Green Mile
Member: 11325 Status: Offline Thanks Meter: 266 | 6680... unable to perform bluetooth operation met this problem. resetting does not fix it. did not try flashing yet to avoid warranty problems. is this a hardware problem or not pls? in 6600 the bluetooth module is mainly the source of the problem. in this case no idea. thanks al |
04-28-2006, 18:39 | #5 (permalink) |
Registered User Join Date: Oct 2005 Location: newzeland Age: 43
Member: 191225 Status: Offline Thanks Meter: 2,097 | hai pls chek ic bluetooth first heat the ic bluetooth ang heat flasher and format any deatil contact [email protected] |
04-29-2006, 09:41 | #10 (permalink) | |
Freak Poster Join Date: Aug 2005 Location: turkey Age: 51
Member: 174769 Status: Offline Thanks Meter: 19 | Quote:
05-09-2006, 13:40 | #13 (permalink) |
No Life Poster Join Date: Aug 2003 Location: Palestine
Member: 36394 Status: Offline Thanks Meter: 250 | 6680 Unable to perform bluetooth operation , flashing didn't solve the problem its more likely hardware WBR A-H-T |
The Following User Says Thank You to A-H-T For This Useful Post: |
01-14-2007, 16:02 | #15 (permalink) |
No Life Poster Join Date: May 2006 Location: U wont beleive Age: 43
Member: 275631 Status: Offline Thanks Meter: 408 | just reball the bluetoth ic.... its placed just under flash ic... if it doesnt wrk..... u need to change the small black ic just near bluetooth ic... its regulater ic... 1000000% tested.. post result |
N70 unable to perform bluetooth operation | Kanwalgee | MT-BOX | 8 | 02-16-2011 14:49 |
Unable to Perform Bluetooth Operation | nicholas1520 | Nokia Hardware & Hardware Repair | 11 | 04-03-2009 22:38 |
6680 - Unable to perform BT operation | sunny_cool | Nokia Base Band 5 ( BB-5 ) | 6 | 02-27-2007 09:36 |
7610 unable to perform Bluetooth operation | roniri | WD2 & APE (Symbian Phones) | 9 | 10-24-2004 21:43 |
