05-20-2007, 16:14 | #1 (permalink) |
No Life Poster Join Date: Feb 2007
Member: 449069 Status: Offline Thanks Meter: 61 | 6681 Dead, Switches On Only When JAf Connected After servicing(Claning), Set Switches On only with JAF Cable Connect To It & Show Inf & Chk Logs & works Fine(with JAF cable connected). Set Doesn't shows Charging(On/Off Switch Ok). With Battery It Doesn't Switch On at all. Here are the Inf Log ------------------------------ FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V 04wk47_m_v14 09-02-06 RM-57 (c) Nokia. HW version: 0906 PCI version: RFIC version: 150a160f DSP version: cho_04wk47v23 LCD version: 8618277 APE SW Core version: V 6.09.00 27-02-06 RM-57 (c) NOKIA. APE Variant version: V 6.09.00-APAC2 27-02-06 RM-57 (c)NOKIA Retu version: 32 Tahvo version: 52 APE HW version: 256 APE ADSP SW version: 52041 Production serial number: CQC341219 Product code: 0536412 Module code: Basic production code: 0538674 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 35188601052**** IMEI spare to net: 3A 15 88 06 01 25 65 02 IMEI SV to net: 33 15 88 06 01 25 65 02 F7 LOCK STATUS: CONFIG KEY: 2440700000000000 Provider: AT&T;U.S.A. (3650) Key Code count: 0 Block 1: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 2: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Searching for saved ini... Checking for file C:\Program Files\ODEON\JAF\JAF_RM-57.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0536412 INI file 0536412.ini is missing. Continue searching for second ini type... No ini files found... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Done! ----------------------------------------------------- Here are CHK log ---------------------------------------------- Booting phone... APE Boot Data: Asic ID: 17100701 Asic Mode ID: 00 Asic Public ID: 801F2F319329AFC2C7AF60948EBF1E57387AEEC3 HASH: 2C05369F57CC3C4CF9E783E83D9B512B00000000 ROM ID: AB5E4ADB27A06946 CMT Boot Data: Asic ID: 000000010000022600010006000C192101002200 Asic Mode ID: 00 Asic EM ID: 00000352 Asic Public ID: 1F000216428C4F51D504CFF298D152E820C96AA8 HASH: E9EFF4BFAA5393217CA6B17755FC3E1400000000 ROM ID: F28A211FCEA7B19D CMT Boot File: C:\Program Files\ODEON\JAF\Flash\rap3gv2_2nd.fg Loader version: 01.14.02 -> Revision: 0000 Patching CMT boot step2... CMT Boot Ready CMT Flash ID: 00020001 CMT Flash Data: 00000000000000000000000000000000 CMT Loader: C:\Program Files\ODEON\JAF\Flash\RAP3Gv3_algo.fg Loader version: 01.14.02 -> Revision: 0000 CMT Loader Ready APE Boot: C:\Program Files\ODEON\JAF\Flash\helen3_2nd.fg Loader version: 01.21.00 -> Revision: 0000 Patching APE boot step2... APE Boot Ready APE Flash ID: 003500EC APE Flash Data: 00020000000600000000000000000000 Done! Restarting phone...Done! ----------------------------------------------------- After Pressing Chk, Phone Starts in Normal mode, Works Perfectly Ok. Even Switches off with on/off key.(All Time JAF Cable Connected) When Battery Connected Set Doesn't Switch On. I Also Tried Shorting Ic as shown in attachment, But in vain. After Pressing CHK, log is Generated & Phone Starts in NORMAL mode. Its the time when u can analyse all functionality of phone even on/Off functions really well(On/off Switch OK). when switched off, it switches on automatically. The Phone Goes In Local/test Mode perfectly. When JAF cable Put out, Phone doesn't Start!!!!!!! Please Help!!!!!! |
G502 switch on only on chager, after disconect charging battery continue | Boshko_Alfa | Sony Ericsson Hardware Repair | 0 | 05-06-2009 13:08 |
3310 switch on only when charger connected | kprajeesh4u | Nokia Hardware & Hardware Repair | 1 | 05-28-2007 09:55 |
T65 powers on only when charged is connected | SVH | Sony Ericsson Hardware Repair | 1 | 08-26-2003 22:15 |
Sharp GX10 switch on only when ... | daz | Hardware Repair by brands | 3 | 05-03-2003 06:49 |
