6681 off line mode hi sir wat to do with 6681 i found sol. for 6680 but does same applys to 6681 also plz reply?????????????? thanx. |
can i place jumper for sim ic couse i dont have sim ic?????????? |
contact the retailer the problam accur in (7610 model) plese give me solutin with image ???? thankssssssssss. |
Nokia 6681/6680 1 Attachment(s) Nokia 6681/6680 offline insert sim card ??? |
for 7610 contect retailer problame just use finger trick in off mode of set press(*+3+send key+on off switch) hold these for key till it shows formating ur problame is solved 1000% tested sol. |
Hai Sir D Same Prob I Have I Cant Understand D Previous Image Help Me Pls......... Adv Thanks |
tryed jumper sol. did not work for me now wat to do ??????????? |
jumper solution is wrong, the ic position is different on board. but as it is, i try different jumpering on this ic, and no good must say my board has some components missing, phone was droped but i don't think this is the correct ic if it is, please post correct jumpering thx you |
thxxxxxxxxx sooooooooooooooo much |
6680 off line mode Quote:
d pict is in d mirror view so shall v understand d concept of d sim reader v can do d work easily for all models 1 simple method fr sim track just v place our left thumb finger in d empty space after removing d sim reader and make jumpers like up & down as shown in d diagram :) |
1 Attachment(s) picture is wrong just as member zullu2004 was writing too, correct picture is here: jumper up-down not left-right ! |
@ PAG_TWEE the ic indicated on board by member hs.com is the sim ic, but the jumper is wrong for this ic it will be right if you turn jumper picture 90 degree right correct jumper posted by member mrfixit thank you mrfixit for this correct jumper |
plese check bis line |
