10-23-2007, 07:10 | #1 (permalink) |
Freak Poster Join Date: May 2007
Member: 515100 Status: Offline Thanks Meter: 73 | 6681 off line mode thanx. |
The Following User Says Thank You to sachin_udai For This Useful Post: |
10-23-2007, 11:59 | #6 (permalink) |
Member: 515100 Status: Offline Thanks Meter: 73 | for 7610 contect retailer problame just use finger trick in off mode of set press(*+3+send key+on off switch) hold these for key till it shows formating ur problame is solved 1000% tested sol. |
01-21-2008, 08:55 | #9 (permalink) |
No Life Poster Join Date: May 2005 Location: Timisoara Age: 43
Member: 146635 Status: Offline Sonork: 100.1651273 Thanks Meter: 261 | jumper solution is wrong, the ic position is different on board. but as it is, i try different jumpering on this ic, and no good must say my board has some components missing, phone was droped but i don't think this is the correct ic if it is, please post correct jumpering thx you |
11-22-2008, 03:49 | #12 (permalink) | |
Major Poster Join Date: Oct 2007 Location: INDIA Tamilnadu Age: 42
Member: 614239 Status: Offline Thanks Meter: 9 | 6680 off line mode Quote:
d pict is in d mirror view so shall v understand d concept of d sim reader v can do d work easily for all models 1 simple method fr sim track just v place our left thumb finger in d empty space after removing d sim reader and make jumpers like up & down as shown in d diagram | |
11-22-2008, 05:17 | #13 (permalink) |
No Life Poster Join Date: Apr 2004 Location: MOON
Member: 60899 Status: Offline Thanks Meter: 792 | picture is wrong just as member zullu2004 was writing too, correct picture is here: jumper up-down not left-right ! |
The Following 3 Users Say Thank You to mrfixit For This Useful Post: |
11-25-2008, 14:15 | #14 (permalink) |
Member: 146635 Status: Offline Sonork: 100.1651273 Thanks Meter: 261 | @ PAG_TWEE the ic indicated on board by member hs.com is the sim ic, but the jumper is wrong for this ic it will be right if you turn jumper picture 90 degree right correct jumper posted by member mrfixit thank you mrfixit for this correct jumper |
6681 off line mode............. | everstarnirmal | Nokia Base Band 5 ( BB-5 ) | 4 | 02-24-2009 14:21 |
n73 off line mode | dt wireless | Nokia Base Band 5 ( BB-5 ) | 20 | 02-19-2009 19:01 |
n73 off line mode | totalmanish | Nokia Hardware & Hardware Repair | 7 | 02-13-2007 06:58 |
9300...off-line mode activated | hamzaa | Nokia Hardware & Hardware Repair | 4 | 03-09-2006 05:27 |
9300...off-line mode activated | hamzaa | UFS2 + UFS3-Tornadoflasher | 2 | 02-02-2006 22:25 |
