Old 06-13-2006, 03:50   #1 (permalink)
hooi76's Avatar
Member: 7741
Thanks Meter: 111
3100 shows not charging by itself without charger
3100 shows not charging by itself suddenly without the charger. I already reflash the whole phone and then patch imei. May i know what is the problem?
Old 06-13-2006, 07:10   #2 (permalink)
murtaza_nns's Avatar
Member: 247987
Sonork: 100.1609015
Thanks Meter: 542
3100 not charging
You can take help from these pictures.
Old 06-13-2006, 10:23   #3 (permalink)
Registered User
Member: 86890
Thanks Meter: 9
at times the problem as to do with the fuse. try changing fuse or short circuit
Old 06-13-2006, 10:27   #4 (permalink)
baraka42's Avatar
Member: 14578
Thanks Meter: 831
@ hooi76,
pls. try to clean pcb with ultrasonic cleaner
wbr
Old 06-13-2006, 10:50   #5 (permalink)
Member: 70916
Thanks Meter: 56
hai for 3100 when we connect the charger it shows not charging any solution ?
Old 06-14-2006, 11:18   #6 (permalink)
hooi76's Avatar
Member: 7741
Thanks Meter: 111
i already clean the phone, and i reball the cpu too, the lcd still show the [not charging].
and worst is after reballing the cpu, sometimes the other party can not hear from my voice.
is it UEM problem that causes the phone shows [not charging] WITHOUT CHARGER.
and now other party can not hear my voice. is this also related to UEM too?
Old 06-14-2006, 11:27   #7 (permalink)
baraka42's Avatar
Member: 14578
Thanks Meter: 831
@ hooi76,
now all is clear. pls. check voltage at battey connector with charger pluge in and without battery. if there is 3.6 volt. then just change UEM. and after procces, all problem will be solved.
wbr
Old 06-14-2006, 12:04   #8 (permalink)
..::ArchitRaj::..'s Avatar
Member: 181696
Sonork: 100.107830
Thanks Meter: 5,406
yes hooi76 this is uem problam
rebaall or change uem
Old 06-14-2006, 14:30   #9 (permalink)
Member: 281448
nokia3100 not charging on dispay
it's either uemor v100 problem
Old 06-14-2006, 17:29   #10 (permalink)
hooi76's Avatar
Member: 7741
Thanks Meter: 111
hot the uem today (maybe dry solder) and untill now, the phone works normal again, will post results again tomorrow. thanks everbody.
Old 06-27-2007, 02:06   #11 (permalink)
hooi76's Avatar
Member: 7741
Thanks Meter: 111
today i have another 3100 water damaged phone,
I already clean the pcb, reball the CPU, UEM, Flash IC, MJOLNER and PA. CHnage the buzzer ic cos it;s burnt. And now it shows not chanrging by ITSELF too. What is the problem?
Please help.
Solution Of Reconnect Charger or Charge By Itself. For 3310 keany Nokia Repair Guide and FAQ 220 03-27-2011 08:02
chinese n95 8gb shows usb config and charges by itself vlatche_mk Chinese Models & Cloned Phones 0 04-05-2009 14:30
HELP Solution for 1100 reconnect charger or charge by itself ? sapatos Nokia Hardware & Hardware Repair 2 08-27-2005 10:33
3100 shows not charging Yoda_Brno Nokia Hardware & Hardware Repair 5 03-04-2005 15:48
Nokia 3610 show not charging when connect with charger TechPhone Nokia Hardware & Hardware Repair 2 01-27-2004 20:29
Page generated in 0.27445 seconds with 10 queries
