Old 10-10-2009, 17:15   #1 (permalink)
Member: 972745
Sonork: 100.1627715
Thanks Meter: 216
6700 camera on standby problem
any solution for this problem thnx..
phone has been flashed =)
The Following 2 Users Say Thank You to shak360 For This Useful Post:
Old 10-10-2009, 18:35   #2 (permalink)
Member: 972745
Sonork: 100.1627715
Thanks Meter: 216
bump.............................
The Following User Says Thank You to shak360 For This Useful Post:
Old 10-10-2009, 18:44   #3 (permalink)
Member: 30623
Thanks Meter: 65
Does it work before flash
The Following User Says Thank You to stetocina For This Useful Post:
Old 10-10-2009, 18:57   #4 (permalink)
Member: 972745
Sonork: 100.1627715
Thanks Meter: 216
Yeah' a flashd it twice no luck
Old 10-13-2009, 10:24   #5 (permalink)
nofear197979's Avatar
Member: 68311
Thanks Meter: 34
plz i have the same problim how to solve it plzzzzzzz
Old 10-13-2009, 14:16   #6 (permalink)
Member: 878934
Thanks Meter: 13
what tool do you use to flash that phone???? i didn't succed whit jaf and mt
"CMT Boot Ready
Error in MSG id...
Error in cmt get id...
Error loading cmt loader..." (jaf error)
%%%%%%%% ERROR BOOTING: " (mt error)
Old 10-28-2009, 17:06   #7 (permalink)
Member: 98619
Thanks Meter: 14
Dear frinds i had the same problem with three telephone. But i realy find the solutation. This is disassembly problem, when u open the telephone the camera flat cabe go displace, then when u start camera u see camera stand by. To solve the problem very gently open the camera and put the flat cable back to the point and assemble the telephone . Camera will work 100%. Check by me today.
The Following 10 Users Say Thank You to tipurus For This Useful Post:
Old 10-28-2009, 17:38   #8 (permalink)
Member: 972745
Sonork: 100.1627715
Thanks Meter: 216
thnx much appreciated
Old 06-04-2010, 12:29   #9 (permalink)
Member: 796640
6700 camera on standby problem .Please help
Old 06-05-2010, 11:05   #10 (permalink)
Member: 266986
Thanks Meter: 5
you must chenged N1421 or flex camera
Old 06-05-2010, 11:44   #11 (permalink)
kadricom's Avatar
Member: 526292
Sonork: 100.1597116
Thanks Meter: 412
try to write dynamic camera with mxkey if still have problem
[Share here] Dynamic Camera Configuration / CAMERA ON STANDBY PATCH
The Following 3 Users Say Thank You to kadricom For This Useful Post:
Old 07-18-2010, 21:32   #12 (permalink)
Member: 144157
Thanks Meter: 3
This is a good solution!!!!!!!!!!!!!!100%
The Following 2 Users Say Thank You to bartok81 For This Useful Post:
Old 07-24-2010, 22:45   #13 (permalink)
Member: 1210000
Thanks Meter: 34
Assalam-o-Alaikum
THANKS tipurus I AM CHACK THIS SOLUTION IS WORK AND NOT SHORT BORD SHOR IS AND 100%
Old 07-24-2010, 22:48   #14 (permalink)
Registered User
Member: 1125280
Thanks Meter: 273
dont flash it just change camera cable 100% tested many times
The Following User Says Thank You to JASKY007 For This Useful Post:
Old 07-24-2010, 23:08   #15 (permalink)
JONONItelecomô's Avatar
Member: 1076772
Sonork: 100.1601881
Thanks Meter: 2,830
try
Phone Memory has 10.7 MB free space. but problem is same camera on standby and blue tooth, radio also not working.
try taking the battery out for a few minutes and see if it changes anything. also consider factory default restore under settings the default code is 12345 and you will not lose any data, but might have to adjust your settings.
thanks
6303 camera on standby problem shak360 Nokia Hardware & Hardware Repair 6 08-20-2010 12:16
PLease Share 6700 Dynamic Camera Configuration / CAMERA ON STANDBY PATCH ServiceTEL MXKEY Nokia Flasher and Unlocker (by Alim Hape) 5 07-18-2010 06:09
6700 camera on standby problem vu24h Nokia Hardware & Hardware Repair 0 03-18-2010 04:31
5220_RM-411 Camera On Standby Problem irfanamin2 Nokia Hardware & Hardware Repair 2 05-02-2009 11:05
camera on standby 6280 says while operating camera gsmservices MT-BOX 0 09-06-2006 17:41
Page generated in 0.40851 seconds with 8 queries
