6700c keypad last solution Nokia 6700c always work before opening it and after assembly it you find no key works unless power key and volume keys the final solution which tested with 2 devices 6700c is disconnect the cam connector and and test it if OK replace the cam connector because of it always broken when opening the mobile . Best Regards. Alkuzaee... |
Wrong advise, this solution had been post and is well written by nokia to inform the technician who work at the service center about the procedure and steps to prevent the cam flex module and the pcb from short circuit. When doing disassemble, remove of camera lens first before remove other parts is one way to ensure and prevent pcb from been short cos the metal clip which connect between the contact point of the camera lens and the flex, once a slight adjustment on the alingment, it will cost short circuit or due to left over solvent like glue which the factory didn't remove properly at the surface of the flex or water damage simply wipe off with alcohol |
6700c keypad solution 100% tested just remove camera module and strip placed under the module and there you can see metal clip place paper on metal and assemble everything . tested 100% by me. |
6700c key sollution by aikuzaee it true if camera strip is short then key doesnt work |
works with me many thanks for solution |
daghang salamat ahooooo !!!!!!!!!!!!!!!!!!!!!!!!!! gerard!!!!!!!!!!!!!!!!!! |
nokia 6700c-1 when power on the phone it ok but the main key not working only power key working |
6700c no power on after changing housing pleaeeeeeseeeeeeee help me i was changing the housing of 6700c and after changing the ph is compltly dead? pc not detecting? i dont know what have i done wrong |
