Old 06-29-2010, 22:08   #1 (permalink)
Member: 300261
Thanks Meter: 28
Thumbs down 6700c keypad last solution
Nokia 6700c always work before opening it and after assembly it you find no key works unless power key and volume keys the final solution which tested with 2 devices 6700c is disconnect the cam connector and and test it if OK replace the cam connector because of it always broken when opening the mobile .
Best Regards.
Alkuzaee...
The Following 4 Users Say Thank You to alkuzaee For This Useful Post:
Old 06-30-2010, 03:28   #2 (permalink)
Member: 36010
Thanks Meter: 42
Wrong advise, this solution had been post and is well
written by nokia to inform the technician who work at the service center about the procedure and steps to prevent the cam flex module and the pcb from short circuit. When doing disassemble, remove of camera lens first before remove other parts is one way to ensure and prevent pcb from been short cos the metal clip which connect between the contact point of the camera lens and the flex, once a slight adjustment on the alingment, it will cost short circuit or due to left over solvent like glue which the factory didn't remove properly at the surface of the flex or water damage simply wipe off with alcohol
Old 10-25-2010, 15:10   #3 (permalink)
Member: 227355
Thanks Meter: 15
6700c keypad solution 100% tested
just remove camera module and strip placed under the module and there you can see metal clip place paper on metal and assemble everything . tested 100% by me.
The Following 2 Users Say Thank You to irfane74 For This Useful Post:
Old 12-03-2010, 20:56   #4 (permalink)
Member: 943447
Thanks Meter: 51
Best Regards.
Alkuzaee...
good work it work for me thanks
The Following User Says Thank You to mobileland139 For This Useful Post:
Old 12-11-2010, 09:04   #5 (permalink)
Member: 615719
6700c key sollution by aikuzaee
it true if camera strip is short then key doesnt work
Old 04-20-2011, 02:36   #6 (permalink)
mobilagy's Avatar
Member: 217479
Thanks Meter: 267
works with me
many thanks for solution
The Following User Says Thank You to mobilagy For This Useful Post:
Old 07-24-2011, 15:14   #7 (permalink)
Member: 1269707
Sonork: gerard[virus]
daghang salamat ahooooo
!!!!!!!!!!!!!!!!!!!!!!!!!! gerard!!!!!!!!!!!!!!!!!!
Old 09-28-2011, 13:50   #8 (permalink)
shindasinghvip's Avatar
Member: 1392939
Thanks Meter: 26
Best Regards.
Alkuzaee...
works with me
Old 11-05-2011, 09:32   #9 (permalink)
Member: 869128
Thanks Meter: 60
nokia 6700c-1 when power on the phone it ok but the main key not working only
power key working
Old 01-25-2012, 20:53   #10 (permalink)
Member: 745365
Thanks Meter: 13
6700c no power on after changing housing
pleaeeeeeseeeeeeee help me
i was changing the housing of 6700c and after changing the ph is compltly dead? pc not detecting? i dont know what have i done wrong
Anybody know solution Robi Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 12-10-2014 12:35
Solution for GSM phones!?!?!?!? todosije Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 12-16-2010 05:52
Pic Solution jan Nokia Hardware & Hardware Repair 8 10-11-2010 11:56
5110 version 5.24 solution lampin Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 11-14-1999 07:00
!!!!!!TO ALL NOKIA 51XX/61XX SP LOCKS 1,2,3,4 SOLUTION latest news!!!!! spterminator Main Sales Section 2 08-13-1999 06:55
Page generated in 0.36008 seconds with 8 queries
