Old 03-29-2010, 11:09   #1 (permalink)
Member: 430612
Thanks Meter: 274
6700c keypad problem
how to fix keypad nokia 6700c
The Following 2 Users Say Thank You to luyanda For This Useful Post:
Old 03-29-2010, 11:16   #2 (permalink)
ANILMPLY's Avatar
Member: 1268409
Thanks Meter: 57
sir,
pls explain once more,
The Following User Says Thank You to ANILMPLY For This Useful Post:
Old 03-29-2010, 11:18   #3 (permalink)
tsavofather's Avatar
Member: 326603
Thanks Meter: 25
Post the exact problem so that others can help you
The Following User Says Thank You to tsavofather For This Useful Post:
Old 03-29-2010, 14:15   #4 (permalink)
Member: 430612
Thanks Meter: 274
when power on the phone it ok but the main key not working only
power key working
The Following User Says Thank You to luyanda For This Useful Post:
Old 03-29-2010, 15:52   #5 (permalink)
ANILMPLY's Avatar
Member: 1268409
Thanks Meter: 57
pls u change that keypad cable
Old 03-29-2010, 15:53   #6 (permalink)
Crazy Poster
Member: 639799
Thanks Meter: 3
i had same problem take all out assemble them and try if all work fine
try put the keypad carefully or change it check the connectors might be litthie crack kin it ok
The Following User Says Thank You to peacengell For This Useful Post:
Old 03-29-2010, 23:53   #7 (permalink)
mr. nokia's Avatar
Member: 73117
Thanks Meter: 31
No no search before post
it's a camera problem remove it & resolder it 100% tested
The Following User Says Thank You to mr. nokia For This Useful Post:
Old 04-01-2010, 16:21   #8 (permalink)
Member: 1266131
Thanks Meter: 3
6700c keypad not working
The Following User Says Thank You to alshara For This Useful Post:
Old 06-22-2010, 23:43   #9 (permalink)
Member: 549228
Thanks Meter: 12
i have almost the same problem.power on without keypad.but when i put back keypad not power on.just i change cover it was work good
The Following User Says Thank You to akarkon For This Useful Post:
Old 02-03-2011, 09:39   #10 (permalink)
Member: 397862
Thanks Meter: 176
power key working
i face same problem anyone have any solution
The Following User Says Thank You to imran_panipat For This Useful Post:
Old 02-03-2011, 10:12   #11 (permalink)
Member: 1499467
Thanks Meter: 4
and me.
a have problem with 6700c kebord not vork
sory for my english
The Following User Says Thank You to mobyshop For This Useful Post:
Old 02-04-2011, 03:59   #12 (permalink)
r a nadeem's Avatar
Member: 241039
Thanks Meter: 4,168
Nokia 6700c always work before opening it and after assembly it you find no key works unless power key and volume keys the final solution which tested with 2 devices 6700c is disconnect the cam connector and and test it if OK replace the cam connector because of it always broken when opening the mobile .
Rashid Ahmed Nadeem
The Following 10 Users Say Thank You to r a nadeem For This Useful Post:
Old 02-04-2011, 04:57   #13 (permalink)
dil7689's Avatar
Member: 1080396
Thanks Meter: 1,661
good job .............
The Following User Says Thank You to dil7689 For This Useful Post:
Old 02-24-2011, 12:46   #14 (permalink)
Crazy Poster
Member: 902714
Thanks Meter: 5
good work.........
Rashid Ahmed Nadeem
it,s good work and nice .............thanks
Old 02-24-2011, 18:13   #15 (permalink)
Member: 972454
Thanks Meter: 6
hello sir,
i have one 6700c,its physical damage,i change display and antenna setup after keypad is not working.i check the pcb one small ic is damage(its look like display ic and also it have 25balls 5*5 rows.its little smaller than n70 display ic and it not proper fit in that place)but i want know one think are the 6700c have separate ic for keypad or not.if it have where is it. and which ic equal for this
6700c bluetooth problem goanga Nokia Base Band 5 ( BB-5 ) 12 07-28-2010 12:06
6700c flashing problem dune2 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 2 02-06-2010 17:42
6700c display problem evereastern Nokia Hardware & Hardware Repair 0 01-12-2010 09:35
6700c flashing problem jijeesh HWK 3 12-16-2009 13:03
6700c flash problem cupon Cyclonebox 7 10-01-2009 20:38
Page generated in 0.43148 seconds with 9 queries
