Old 05-15-2003, 00:47   #1 (permalink)
Crazy Poster
Member: 28660
Thanks Meter: 9
Red face 7110 net proplem
plz i hv 7110 without net what can i do?
plz give photo with reply
Old 05-16-2003, 00:50   #2 (permalink)
GSMWolf's Avatar
Member: 4454
universal answer: read service manual....
Rehot ccont, cobba, hagar with flux.....
Wolf.
Old 05-16-2003, 03:32   #3 (permalink)
Crazy Poster
Member: 28660
Thanks Meter: 9
Unhappy thanks but .........
thanks but realy do that without result
so what do u recomend to do?????????????????????
Old 05-16-2003, 03:52   #4 (permalink)
Member: 26504
Thumbs up Checking procedure No Signal for NOKIA
The simple procedure for the problem No Signal at Nokia...
Activated Net Monitor Menu using Logo Manager or others...
Choose menu 01... at Net Monitor Menu.. It will be shown what the problem... PA or Antenna Switch...
Check at the Menu phone setting -> Select Network -> Manual
Remember: If the phone cannot received how it can be transmit ?
For Received is PA, for Transmit use Antenna Switch and HAGAR
The procedure is :
PA -> ANTENNA SWITCH (DUPLEXOR) -> Rx/Tx -> HAGAR (SIGNAL PROCESSOR) -> COBBA -> PA
PA is the IC 90% never damaged...
If You already rehot the PA, HAGAR, CCONT and COBBA but the PB still the same here is my suggestion:
Change the Antenna Switch & HAGAR...
Sometimes for No signal PB there is the COBBA (Audio IC) and CCONT (Power IC) trouble...
Refull Flash 'cause the front end of PPM at HAGAR (SIGNAL PROCESSOR) and don't forget to Open 4SP Lock and then Up Date FAID 3 times....
Hope this will be help out...
Successfull for all of us...
Old 05-16-2003, 04:11   #5 (permalink)
Crazy Poster
Member: 28660
Thanks Meter: 9
mny thanks hani now i will try then will answer u the result
www.simemu.cjb.net and [email protected] (ALLOWABLE) simemu Sim Cloning and Scaning 1 07-31-2003 10:53
net of 7110 scary Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 05-15-2003 00:35
7110 dead after Net Monitor sonoale Nokia Hardware & Hardware Repair 5 02-26-2003 14:42
nokia 7110 NCE-5 V04.80 proplems AMTX99 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 10-04-2000 10:08
Page generated in 0.26798 seconds with 8 queries
