11-11-2005, 16:41 | #1 (permalink) |
Cheater -Don't Deal with him- Join Date: Apr 2005 Location: Iclouds
Member: 142219 Status: Offline Sonork: 100.107814, Thanks Meter: 368 | 7210 No Lights i hav 7210 with broken lcd jack,isold jumpers and display is ok now but thr is no light in keypad n display.plz explain me why? or attach a image related this fault thanx in advance. |
11-11-2005, 21:28 | #2 (permalink) |
No Life Poster Join Date: Sep 2003 Age: 66
Member: 39601 Status: Offline Thanks Meter: 13 | Here is an image of lights drivers in nokia 6610/7210 , includes the keypad socket tracking . Check the tracks U made ,also check if makes short to it with ground , if all is good , check the pathway components with a mutimeeter , if every thing is OK replace the IC it self (N300). GoodLuck |
12-01-2005, 02:35 | #5 (permalink) |
Junior Member Join Date: Nov 2005
Member: 202427 Status: Offline Thanks Meter: 0 | HI you must make this problem step by step : 1. measure +13.5V on V300 this volt used for lighting the LCD .if not found check V300-V301 (zener diode) L300. measure 4v at pin 1. replace N300. if all is replace UEM . 2. if there is +13.5 on V300 check the connector X302 and tracks or replace it . replace the LCD . if all is good replace UPP . you can see the diagram to help you . thanks |
e 315 no light in display. display working ok but no light | shahi | Samsung Hardware Repair | 0 | 01-30-2007 06:23 |
T610 no light Keyboard no light Display | chip_2000 | Sony Ericsson Hardware Repair | 10 | 02-15-2006 15:52 |
7210 led no lights!!!! | lucik | Nokia Hardware & Hardware Repair | 8 | 03-19-2005 14:51 |
Nokia 6600 no lights on lcd and no lights on key's | floky | Nokia Hardware & Hardware Repair | 2 | 02-17-2005 15:01 |
7210 no light | tatalko | Nokia Hardware & Hardware Repair | 3 | 01-14-2004 17:09 |
