Old 11-08-2009, 08:46   #1 (permalink)
Member: 812422
Thanks Meter: 18
7210 supernova not enough memory
7210 supernova shows not enough memory from gallery when play video
Old 11-08-2009, 08:49   #2 (permalink)
Member: 823633
Thanks Meter: 1,705
bro flash lettest Rm-436_7210Supernova_7.23
Old 11-08-2009, 08:51   #3 (permalink)
imran zafar's Avatar
Member: 328187
Thanks Meter: 1,687
formate ur set.............
Old 11-08-2009, 11:02   #4 (permalink)
Member: 993362
Thanks Meter: 18
Flash Usb cable problem solved 100%
Thankx
Old 11-08-2009, 21:56   #5 (permalink)
mr. nokia's Avatar
Member: 73117
Thanks Meter: 31
for sure try to reflash the set if not solve check hardware specially flash ic
Old 11-08-2009, 22:25   #6 (permalink)
BHARGAV's Avatar
Member: 126000
Sonork: 100.1593044
Thanks Meter: 111
I have same problem i do in software
I have same problem i do in software.flash u r phone it will be ok
Old 11-09-2009, 04:54   #7 (permalink)
Member: 1086393
Thanks Meter: 771
Flash your phone with 7.21 it will be surely ok
Old 11-09-2009, 05:00   #8 (permalink)
mobilecitycbk's Avatar
Member: 475440
Sonork: 1604067
Thanks Meter: 965
Format user area its the problem in user area becoz of virus
Old 11-09-2009, 05:16   #9 (permalink)
Member: 619199
Thanks Meter: 47
bro check free size on phone memory and memory card,,,,, then goto flash.....
The Following User Says Thank You to imran87132 For This Useful Post:
Old 11-09-2009, 06:01   #10 (permalink)
Member: 770229
Sonork: 29050
Thanks Meter: 101
Old 11-09-2009, 06:38   #11 (permalink)
Member: 1033689
Thanks Meter: 31
flash with update virsion problem ur solved
The Following User Says Thank You to gsm_probir For This Useful Post:
Old 11-09-2009, 08:26   #12 (permalink)
Member: 638418
Thanks Meter: 52
YES BROTHER FLASH YOUR MOBILE 100% SOLVED
Old 11-14-2009, 10:46   #13 (permalink)
DomnulV's Avatar
Member: 1447
Thanks Meter: 97
BRO..is flashed with 7.23...same trouble..bro..
Solutions?
Old 10-17-2010, 05:55   #14 (permalink)
.:.GSM-ANGEL.:.'s Avatar
Member: 69984
Thanks Meter: 170
Old 10-17-2010, 06:06   #15 (permalink)
israrbjr's Avatar
Member: 748544
Sonork: 100.1601881
Thanks Meter: 173
Solutions?
flash with mx kry then only do full factroy deflaut..
i chacked yasterday and work 100% for me..
The Following User Says Thank You to israrbjr For This Useful Post:
7210s not enough memory X-TRA Universalbox 7 05-17-2010 12:41
7210s 5220 not enough memory solution is here amirsaishi Nokia Base Band 5 ( BB-5 ) 10 03-30-2010 14:12
7210c not enough memory prob not solve see log navnath randive MXKEY Nokia Flasher and Unlocker (by Alim Hape) 14 03-18-2010 15:46
nokia 7210 not enough memory pawank Nokia Base Band 5 ( BB-5 ) 3 11-28-2009 12:07
6600 not enough memory schecska WD2 & APE (Symbian Phones) 7 12-01-2006 10:50
Page generated in 0.31039 seconds with 10 queries
