08-30-2009, 15:27 | #3 (permalink) |
No Life Poster Join Date: Jun 2006 Location: Afghanistan Kabul
Member: 295886 Status: Offline Sonork: 100.1583369 Thanks Meter: 1,472 | write modified pm after using sx4 server if not than ur phones need BB5 rpl nokia server which is down at the time. it will better to post info and self log here |
08-30-2009, 15:32 | #4 (permalink) |
No Life Poster Join Date: Aug 2002 Location: india Age: 63
Member: 14578 Status: Offline Thanks Meter: 831 | if your log saw this, LOCK STATUS: CONFIG KEY: 0000000000000000 PROVIDER KEY: 0000000000000000 Provider: Unknown provider Key Code count: 0, FBUS Code count: 0 you need rpl wbr |
08-30-2009, 19:22 | #5 (permalink) |
No Life Poster Join Date: Mar 2007 Location: (UAE)(pak)
Member: 479496 Status: Offline Sonork: 1592751 Thanks Meter: 404 | here is log LOCK STATUS: CONFIG KEY: 0000000000000000 PROVIDER KEY: 0000000000000000 Provider: Unknown provider Key Code count: 0, FBUS Code count: 0 |
08-30-2009, 19:59 | #9 (permalink) | |
Freak Poster Join Date: Dec 2004 Location: I N D I A Age: 43
Member: 100579 Status: Offline Sonork: 100.1578318 Thanks Meter: 106 | Quote:
Regards! | |
08-31-2009, 08:14 | #12 (permalink) |
Freak Poster Join Date: Jul 2007 Location: murtha
Member: 540170 Status: Offline Thanks Meter: 101 | mostly SL3 phone with contact service problem the only solution is RPL Code: CONFIG KEY: 0000000000000000 PROVIDER KEY: 0000000000000000 Provider: Unknown provider |
08-31-2009, 08:47 | #13 (permalink) |
No Life Poster Join Date: Jun 2007 Location: Rangpur Bangladesh
Member: 526223 Status: Offline Sonork: 100.1605395 Thanks Meter: 106 | JAF version 1.98.64 Detected PKEY: 9000AB99 Card life counter: 99.99% P-key nokia module version 01.02 Detected JAF INTERFACE version: 01.B1, Driver version: 40000, Library version: 30118 JAF DCT4/BB5 LOADERS DIR: C:\Program Files\ODEON\JAF\Flash\ JAF DCT4/BB5 PRODUCT DIR: C:\Program Files\Nokia\Phoenix\Products\ JAF USB LOADERS DIR: C:\Program Files\ODEON\JAF\FlashUSB\ JAF DCT3/DCTL LOADERS DIR: C:\Program Files\ODEON\JAF\Flash3\ USB Cable Driver version: 7.0.2.0 Changing mode...Done! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V 05.60 10-12-08 RM-436 (c) Nokia HW version: 1001 PCI version: RFIC version: 06540601 DSP version: ICPR72_08w47 LCD version: SEIKO PPM version: V 05.60 10-12-08 RM-436 (c) Nokia MR BT MCM version: 2222-143C Retu version: 15 Tahvo version: 22 Content Pack version: Content: mr_ny V 05.60 10-12-08 RM-436 (c) Nokia Production serial number: DTC955740 Product code: 0572571 Module code: 0203868 Basic production code: 0563951 Flash code: Order number: Product specific data: Long production SN: 0 ATO: Default SN type: IMEI plain: 351962031262260 IMEI spare to net: 3A 15 69 02 13 62 22 06 IMEI SV to net: 33 15 69 02 13 62 22 26 F5 LOCK STATUS: CONFIG KEY: 0000000000000000 PROVIDER KEY: 0000000000000000 Provider: Unknown provider Key Code count: 0, FBUS Code count: 0 Searching for saved ini... Checking for file C:\Program Files\ODEON\JAF\JAF_RM-436.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0572571 Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-436\ Searching for default location of ini... Checking path: \Products\RM-436\ Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-436\ No ini files found... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Done! PLZ HELP |
08-31-2009, 09:13 | #14 (permalink) | |
Member deceased !! Join Date: Jan 2008 Location: DreamSunlock Canada,TH,CN,BD Age: 36
Member: 670820 Status: Offline Sonork: 100.1583728 Thanks Meter: 1,348 | Quote:
7210c contect service problem | TUR@N ALAM | J.A.F. By Jafsupport.com | 7 | 01-23-2010 19:09 |
7210C contect service | waqas_ali601200 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 5 | 12-08-2009 15:16 |
7210c contect service | umadineshdas | HWK | 2 | 09-01-2009 14:30 |
7210c Contect service help | thethi | HWK | 7 | 07-03-2009 07:40 |
7210c contect service | ranagaurav | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 05-25-2009 05:39 |
