05-20-2011, 05:51 | #3 (permalink) |
No Life Poster Join Date: Dec 2007 Location: Nepal
Member: 667126 Status: Offline Sonork: 100.1651201 Thanks Meter: 229 | Solution ur problem 1. Check ur LCD -- change again 2. Check ur conector LCD in ur front board -- clean, resolder or change. 3. Check all track ur display conector, if cut -- please jumper 4. Check ur conector falexsible in ur front board -- clean, resolder or change 5. check ur flexible -- clean the conector or change with original flexible (if not original-- change the conector in flexible with original conector) 6. check ur conector flexibel in ur main board -- clean, resolder or change 7. Check track from conector to display IC --- if cut-- jumper 8. Check ur display IC -- reheat, reball or change good luck |
BLUE light | Delfo | Nokia Hardware & Hardware Repair | 8 | 09-20-2002 04:28 |
6110 LCD Contrast Changing??? | Prodigal | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 07-14-2000 18:52 |
Blue LEDs in your Display SUPER! | GM | Nokia Hardware & Hardware Repair | 0 | 06-25-2000 12:47 |
blue Display in Nokia Cellphones | TheDon | Nokia Hardware & Hardware Repair | 0 | 10-29-1999 18:28 |
blue led? | Michael Go | Wanted Products | 0 | 09-10-1999 00:57 |
