Old 12-16-2003, 22:12   #1 (permalink)
Member: 27226
7250 network fault
i gota a 7250 and it gets signal on o2 and voda
when i insert t-mobile or orange it gets nothing and if i do a manual serach and select the network then i get "NO ACCESS"
wat does this mean and how can i sort it out
if u need any more info email me
[email protected]
Old 12-20-2003, 09:18   #2 (permalink)
Member: 31604
Thanks Meter: 12
try changing the p.a and ur problem is solved
Old 12-22-2003, 06:38   #3 (permalink)
hakima's Avatar
Member: 33804
Thanks Meter: 22
YES AFTER THAT 100% OK!!!!
Old 06-12-2004, 01:28   #4 (permalink)
*A*S*H*'s Avatar
Member: 60098
what does p.a mean ?! how do i do it ?
Old 06-12-2004, 11:16   #5 (permalink)
pupy_jai's Avatar
Member: 68635
p.a mean power amp i/c
Old 06-12-2004, 23:21   #6 (permalink)
shadi's Avatar
Member: 35002
Sonork: 100.98829
Thanks Meter: 167
thank you great work
Old 06-13-2004, 15:13   #7 (permalink)
*A*S*H*'s Avatar
Member: 60098
I thought changing the power amp was only for when a phone doesn't power on, i'll give it a try. Thanks
Old 06-13-2004, 16:58   #8 (permalink)
nlogomaster's Avatar
Member: 16816
Sonork: 100.42691
Thanks Meter: 105
you mistook the power AMP ic to power SUPPLY ic for phones doesnt power on, power AMP ic AMPLIFY the pre-amped x'mitted signal to a stronger WATTS,
i wonder why some of you PEOPLE advice to change p.a. while it HAS SIGNAL TO o2 and voda (thats two networks,hence the phone is working good), haven't you heard of BLOCKED/BLACK LISTED PHONES???
Old 08-14-2004, 11:14   #9 (permalink)
Member: 77671
how can i know WD2 phones Flash addresses if i want to erase the flash
Old 08-14-2004, 12:56   #10 (permalink)
asas's Avatar
Member: 5198
Thanks Meter: 2
PA? ) You must cghange IMEI.
Old 11-06-2004, 19:40   #11 (permalink)
Member: 90409
Thanks Meter: 4
hallo
can you send for me a photo that you explane what i have to do exactly . i mean photo for the power AMP ic to power SUPPLY ic for phones doesnt power
7250 signal fault B21Playa Nokia Hardware & Hardware Repair 3 11-05-2006 07:41
7250 camera fault JulesJ Nokia Digital Core Technology 4 ( DCT-4 ) 1 02-01-2005 15:47
7250 network problem usernome Nokia Digital Core Technology 4 ( DCT-4 ) 0 09-21-2004 22:06
7250 Network !!! supremegsm Nokia Hardware & Hardware Repair 6 04-12-2004 07:47
7250 InfraRed fault nickjspencer Nokia Digital Core Technology 4 ( DCT-4 ) 3 01-06-2004 12:37
Page generated in 0.18231 seconds with 9 queries
