7250i dead but charging ok I have a 7250i 3 days used, it was returned dead, flashed with twister ok but still will not power on, i tried to connect the charger and the phone charges but still won't power on... any suggestions? |
Have you checked the switch? |
Check / change power switch, cos when you flashed it, it'll automatically power up. [email protected] |
try to flash it with griffin |
i already did all of the above still the same, griffin doesn't finish flashing the phone.. :) |
use griffin and write eraze files |
griiffin error is, "flashing failed, do you want to retry operation..." i have changed uem and now it powers onbut is in "contact service" tried to download it to 7250 but just shows "blank screen" then powers off.. :) |
You can't downgrade @ 7250 and you can't change uem without write imei! |
you mast rebuild imei |
7250i--->7250 After u downgrade 7250i (ver.4.63) to any version,then ur phone can't be 7250i anymore.After flashing to 7250 the Lcd show blue screen that's mean u got to change another LCD..But the old one still can use for other phone..Hope this can help u... |
flashing to 7250i again if it show contact service then u must flash it to 7250.. |
Contect me. I help you. This is very simple solution :) |
I donīt know why but i have 7250i i have just downgraded it to 7250 and the LCD goes perfectly i thing the LCD is the same |
