Old 02-21-2004, 10:43   #1 (permalink)
Keke's Avatar
Member: 12733
Thanks Meter: 26
3310 Just insert battery and it powers on
I have a 3310 Water dammage and No power : Connect to rolis flasher and it says swich mobile off .
Clened water and rehot pcb, now phone contact service (mcu) but the problem is the phgone goes on automatically after insert battery.
Under BGA shorts but I need your advice please.
Cheers
Old 02-21-2004, 19:00   #2 (permalink)
Member: 21232
Cheers
clean up or change power switch, i try this before
Old 02-21-2004, 21:06   #3 (permalink)
veeresh's Avatar
Member: 26209
Thanks Meter: 2
replace interface IC & check
Old 02-21-2004, 23:02   #4 (permalink)
Member: 44738
just clean pcb well , change power sw. it will gonna be ok....
Old 02-23-2004, 07:48   #5 (permalink)
Keke's Avatar
Member: 12733
Thanks Meter: 26
Power Sw and interface Ic ok
Old 02-23-2004, 12:47   #6 (permalink)
Member: 39601
Thanks Meter: 13
@keke..
In water deffects causes are hazard as U know , I think it could be some residuals under the ccont from the water , a triguer to the power on control pin with up to 50kohm to ground , makes that signe.
Try to reflow ccont ,the flow of the flux with hotgun under it cleans pins ,try it with a good luck.
Old 02-23-2004, 18:47   #7 (permalink)
veeresh's Avatar
Member: 26209
Thanks Meter: 2
clean the pcb with ultrasonic cleaner try if u dont succed.flash it with good flash file.
still if u dont succed remove all the ic except cpu & refix & try.good luck.
Old 02-25-2004, 13:53   #8 (permalink)
Member: 52884
Thanks Meter: 13
Cool
pls i need some assistance i need guide on to replace bga IC ;to make d phone power-on .
Old 02-25-2004, 21:24   #9 (permalink)
veeresh's Avatar
Member: 26209
Thanks Meter: 2
if u r using new ic its ready to fix only thing u have do is remove the old ic clean the pcb remove extra solder lead from pcb apply little liquid flux on pcb where u fix the ic then place the ic correctly & use hot airgun use right nozzel keep the temp at 250-270 deg, air at 3 to 4. (this setting vary from each instrument depends on which use u have get tuned to it by practice).and flow the hot air 30-60seconds.clean the pcb dry it switch on
Old 04-02-2004, 12:24   #10 (permalink)
blue1's Avatar
Member: 60613
change on-off button
Old 05-11-2004, 16:49   #11 (permalink)
gsmbac's Avatar
Member: 44229
Sonork: 1592530
Thanks Meter: 366
hi
i got same problem and it power off when pressing buttons too.
give me a idea
thanks
Old 05-12-2004, 11:45   #12 (permalink)
Member: 52884
Thanks Meter: 13
Cool
flash d phone,then uudate FAID,UNLOCK,WRITE NEW IMEI.it should be ok
Old 05-12-2004, 18:21   #13 (permalink)
Member: 1060
Thanks Meter: 10
@buschell, "flash d phone,then uudate FAID,UNLOCK,WRITE NEW IMEI.it should be ok"
this is too far , please make sure what is topic and then make correct answer !
@gsmbac
power on by it self..
try to review BTEMP line , or check R224 both side to look is it short to gnd, or remove ccont, and check the pin "E4" is it short to gnd , or check keypad "3" center , is it short to gnd, or check C400, remove it for test it !
regards
Willy
Old 05-12-2004, 20:08   #14 (permalink)
eeprom_flash's Avatar
Member: 58599
Thanks Meter: 2
mate if the phone powers on itself and after u press keys it goes off, it is a switch problem, change it. the swith has bridged up..
Old 05-13-2004, 13:27   #15 (permalink)
Member: 52884
Thanks Meter: 13
Cool
mr willy,i respect u,that u should know that there are different faulty and some times d solution may seem very funny or stupid.but to me there is no harm in trying.The other guy (sorry i forgot d name) said it is d power stiwch.i can bet u that if he rempve d swtich,the phone will still power without d switch.so if u think my suggestion is wrong ,i dont know what to say.This b/cos i have just solve a problem like that 2wks ago.
6030 mobile not power on, on battery and working fine on power supply kashif_khatri Nokia Digital Core Technology 4 ( DCT-4 ) 1 09-19-2009 02:57
3310 and 6101 power on only with cable?!!!any solution? jawad8305 Nokia Hardware & Hardware Repair 8 06-11-2008 21:18
help 3310 in tornado it power on but with batterie it not power on sofiame2006 Nokia Hardware & Hardware Repair 3 08-02-2005 08:46
Nokia 3310 Now And Then Power On haider Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 11-03-2004 16:58
insert batterie 6210 auto power on!!! !!!TaaTTalTi!!! Nokia Hardware & Hardware Repair 5 02-21-2003 14:03
Page generated in 0.19182 seconds with 9 queries
