Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Nokia > Nokia Hardware & Hardware-Repair Area
Nokia Hardware & Hardware-Repair Area all what you need for Hardware Repairing for Nokia Phones. Before writing any thread here try to check the Frequently Asked Questions Section.
Old 03-20-2004, 20:51   #1 (permalink)
Member: 28095
7250i Sim card reader contacts broken HOW to fix????
A Customer has brought a phone to me which that have tried to repair themselves, the sim card reader contacts have been totally ripped off the board (all six of them) !!!
Very bad i know, but i would like to try and fix it, does any one know where the pads lead to ?
As i could solder some thin wire from that point to the sim card reader pads and solder them to the legs of the reader, hence gettin it to work (hopefully)
Any help would be greatly appreciated
Regards
NaaN
Old 03-20-2004, 21:36   #2 (permalink)
Own
Member: 5569
Talking
Hi
see old topic [8310 insert sim card] and you can jump directly between R388 with sim connector without rl[resister load bcs. inside R388 have rl]please see schematic diagram of nk7250 or etc[if phone use R388]
Own
Old 03-20-2004, 21:49   #3 (permalink)
Own
Member: 5569
Hi
in your picture if sim connector broken only you can use by this way but broken in line or truehole you shoud check it by schematic[if you can read schematic diagram...so you can fix it EASY]
regards
Own
sorry my english
Old 03-21-2004, 00:08   #4 (permalink)
Member: 28095
I have looked at the schematic but its a bit difficult to understand !!
(i am not expert in electronics, only have a good idea about it)
Old 03-21-2004, 04:24   #5 (permalink)
Own
Member: 5569
Cool
Hi
at R388 use 3 point + volt sim [connect at C203 please you at lay out diagram] = include direct jump = 4 line please you see picture at
insert_sim_card, 8310
please you see at picture and please you see at schematic
1 VSIM connect at C203 = volt bias [+vcc]
2 SIMRST connect at [2 see in picturehttp://forum.gsmhosting.com/vbb/attachment.php?attachmentid=274]
3 SIMCLK connect at [6 see in http://forum.gsmhosting.com/vbb/atta...achmentid=274]
4 SIMDATA connect at [9 see in http://forum.gsmhosting.com/vbb/atta...achmentid=274]
C203 stay at near R388 [ 1 leg to ground , 1 leg = vcc bias to sim direct]
if jump alternate wrong in 234 cant work but no effect to UEM bcs it use little current
5 SIM GROUND jump to ground boad
so if Z301[from 8310],N150 [from 6610,7210] i have schematic for this part i think can modifiy [some body have it?]
Own
Old 03-21-2004, 17:29   #6 (permalink)
Member: 28095
I have tried this method i now have 100% fully working phone!!
THANKS!!
Do you know which point i need to connect on a 7650 for the FBUS RX, the same thing has happened, someone has ripped the pads off!
Thanks
NaaN
Old 03-21-2004, 18:59   #7 (permalink)
b0ba's Avatar
Member: 6772
I can send the rope and the soap to your customer, totaly free.... PM me for your's customer address.
If your customer needs manual how to use the stuff mentioned then mail me.
WBR
b0ba
Old 03-21-2004, 19:33   #8 (permalink)
Member: 28095
lol, ill be sending him a Nice invoice !
Ill be getting him a manual on how to use a soldering iron! the idiot!
NaaN
Old 03-21-2004, 22:41   #9 (permalink)
Own
Member: 5569
Talking
i need to connect on a 7650 for the FBUS RX.........
what's happened? please explain me [sorry my english very bad] but i want help you
br
Own
Old 03-22-2004, 00:22   #10 (permalink)
Member: 28095
the contact pad for the Fbus RX has been ripped off, like the sim card contact pads.
(it is the third connection in the row. Where the datacable goes)
I have attached picture
I need to fix this
Regards
NaaN
Old 03-22-2004, 06:53   #11 (permalink)
Own
Member: 5569
Red face
if fbus have broken please you see at UEM [A7=fbustx,c7=fbusrx]use wire jump to it.but fbus contact have ripped must modify little
regards
Own
Old 03-22-2004, 11:03   #12 (permalink)
Member: 28095
Is that the only place i can jump from?
Does it mean i need to remove the UEM ? and place wire, then put UEM back ?
Old 03-22-2004, 12:20   #13 (permalink)
Own
Member: 5569
Red face
check line between fbusrx point [stay at under UEM by remove before] to contact fbus please see at schematic diagram
regards
Own
Old 08-07-2004, 12:13   #14 (permalink)
Member: 69042
form where i get the diagram for 6610 insert sim
nokia 7210c contact service how to fix ? milandhal Nokia Base Band 5 ( BB-5 ) 29 05-19-2011 17:54
s5600 v phone reeze sim contact reseler how to fix help observer123 NSPRO 2 08-22-2009 19:15
problem after unlocking 6630 contacted reseller how to fix i have pm and rpl files majestic36 Nokia Base Band 5 ( BB-5 ) 8 03-21-2009 22:01
plz card reader not found how to solve melgsm FuriouS TeaM Products 3 09-05-2008 17:07
7210 contact service HOW TO FIX?????? essojay Nokia Digital Core Technology 4 ( DCT-4 ) 2 05-14-2006 17:09
Page generated in 0.53611 seconds with 12 queries
