7260 problem plz Ihave nokia 7260 after flach the power on with cable and not power with batterie plz help |
your problem is on on/off ways or uem. firs to do, the positive way goes from on/off switch to two diots where is under the on/off switch. and than this way is going on from diots to a diot where is at the right and buttom corner of the uem (pfo is top and charge connector is buttom. i cant give the shema because i am out of my city). from this diot to uem is end of the way. check this way. if this way is true. your problem is in uem.. first hot it or be sure under of it is clean. if your problem is still going on, there is no other way changing uem.. good luck |
