11-30-2005, 21:07 | #1 (permalink) |
Freak Poster Join Date: Aug 2004 Location: Riyadh, K.S.A. Age: 49
Member: 77205 Status: Offline Thanks Meter: 4 | 7260 rerpowering i have here 7260 this mobile is working the problem only is charging. so i try to flash in tornado flashing is not finish error repowering. now my mobile is dead please somebody help me.. thank you very much.... |
12-01-2005, 10:04 | #2 (permalink) | |
Freak Poster Join Date: Sep 2003 Age: 48
Member: 39002 Status: Offline Thanks Meter: 22 | Nokia 7260 Quote:
12-01-2005, 18:38 | #3 (permalink) |
Junior Member Join Date: Sep 2004 Location: at my house... hehehehehe
Member: 83247 Status: Offline Thanks Meter: 0 | of course the phone will be dead because the flashing was not completed it is normal, try to clean pin contacts, then earase flash then write higher version of flash then write pm... be sure that the cable and is well connected to the unit otherwise flashing wont be comlpeted and same problem, also before flashing try to "check" if it shows 1st boot ok... 2nd boot ok etc. flash the phone but if it shows 1st boot error bad upp resp. its either contacs on cable or hardware fault try reflowing flash ic... good luck... |
12-01-2005, 22:47 | #4 (permalink) |
No Life Poster Join Date: Mar 2005 Location: Egypt Age: 52
Member: 129676 Status: Offline Thanks Meter: 39 | if after flash and pm the phone and the charging not work this problem will be hardware so you need to reviow the path of charging circuit if oll is ok you need to chang the UEM ic |
7260 flash files and pin out | afacandenis | Nokia Digital Core Technology 4 ( DCT-4 ) | 2 | 11-11-2004 00:26 |
7260 pinout & IMEI "rebuild" | Toto | Nokia Digital Core Technology 4 ( DCT-4 ) | 8 | 11-08-2004 13:48 |
7260 flash file | cellcare | Nokia Digital Core Technology 4 ( DCT-4 ) | 5 | 11-03-2004 11:44 |
New Nokia Phones-9300, 7260, 7270, 7280 | Yolly Zubrick | Off Topic Zone | 2 | 09-11-2004 14:27 |
NEW Nokia 7280, Nokia 7270, Nokia 7260 | sandrita | Nokia Digital Core Technology 4 ( DCT-4 ) | 0 | 09-09-2004 15:39 |
