7310 supernova 7.8 9. keypad not working sulotion jumper ways for 7,8,9 keypad not working. http://img505.imageshack.us/img505/3609/2uza535.png tested by me. |
this solution does not work.. i wasted half an hour on it !! |
this SOLUTION IS NOT WORK tested yesterday |
tested and work . thks bro :) |
its working just change board connector |
The solution is perfect. It works 100%. Tested today on 7310s. You need to make sure the wire doesn't connect to the metal plate of the keypad so it does not short. Regards. |
same for 5310 and 7210c solution |
1 Attachment(s) verifY and resolder keypad ways |
nice sharing its took 15-45 minuts easy step is change the flex within 10 minuts |
you need change the IC or try this solution. |
yes its easy to change keypad flex rather than making temporary jumper |
thank's this SOLUTION IS good ............. |
