Old 07-24-2009, 04:35   #1 (permalink)
Member: 920176
Thanks Meter: 81
7310 supernova 7.8 9. keypad not working sulotion
jumper ways for 7,8,9 keypad not working.
tested by me.
The Following 6 Users Say Thank You to popex For This Useful Post:
Old 01-28-2010, 08:56   #2 (permalink)
Crazy Poster
Member: 246869
Thanks Meter: 3
this solution does not work.. i wasted half an hour on it !!
The Following User Says Thank You to alltech18 For This Useful Post:
Old 01-28-2010, 09:15   #3 (permalink)
Member: 818748
Sonork: 00000
Thanks Meter: 44
this SOLUTION IS NOT WORK
tested yesterday
Old 01-28-2010, 23:31   #4 (permalink)
Member: 411207
Thanks Meter: 164
tested and work .
thks bro
Old 01-29-2010, 09:00   #5 (permalink)
rohinikumar's Avatar
Member: 988910
Sonork: 100.1646548
Thanks Meter: 21
its working
just change board connector
Old 02-03-2010, 11:47   #6 (permalink)
Member: 323255
Thanks Meter: 67
The solution is perfect. It works 100%. Tested today on 7310s. You need to make sure the wire doesn't connect to the metal plate of the keypad so it does not short.
Regards.
The Following User Says Thank You to alex_ionut2003 For This Useful Post:
Old 02-03-2010, 11:49   #7 (permalink)
Member: 180806
Thanks Meter: 2
same for 5310 and 7210c solution
Old 02-09-2010, 16:34   #8 (permalink)
Member: 208195
Thanks Meter: 107
verifY and resolder keypad ways
The Following 3 Users Say Thank You to dan1gsm For This Useful Post:
Old 02-09-2010, 19:18   #9 (permalink)
VIBINDAS_INDIA's Avatar
Member: 707582
Sonork: 100.1620432
Thanks Meter: 334
nice sharing
its took 15-45 minuts
easy step is change the flex within 10 minuts
Old 02-09-2010, 19:25   #10 (permalink)
Member: 411207
Thanks Meter: 164
Originally Posted by VIBINDAS_INDIA View Post
nice sharing
not true.also change the flex and not work
you need change the IC or try this solution.
Old 02-09-2010, 19:33   #11 (permalink)
Member: 583454
Thanks Meter: 80
yes its easy to change keypad flex rather than making temporary jumper
The Following User Says Thank You to waqarN70 For This Useful Post:
Old 02-18-2010, 13:08   #12 (permalink)
Member: 1200462
Thanks Meter: 3
thank's
this SOLUTION IS good .............
The Following User Says Thank You to kadour1 For This Useful Post:
7310c 7,8,9 key not working solution here! biniesh_08 Nokia Hardware & Hardware Repair 12 07-30-2013 18:31
V3 keypad 7,8,9,*,down not working kenjimoh Motorola Hardware Repair 2 05-18-2009 19:16
7310c 7,8,9 buttons not work rohinikumar Nokia Hardware & Hardware Repair 0 04-04-2009 12:12
3310 7,8,9, button not working bruce77 Nokia Hardware & Hardware Repair 2 12-05-2005 10:30
Page generated in 0.25673 seconds with 10 queries
