12-04-2008, 19:24 | #1 (permalink) |
Freak Poster Join Date: Jan 2008 Location: punjab ,jalandher
Member: 672494 Status: Offline Thanks Meter: 109 | 7310c keypad problem |
12-04-2008, 20:31 | #2 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Estonia Age: 37
Member: 154612 Status: Offline Thanks Meter: 824 | U tried changing both ic`s? They are both responsible of keypad fault`s. Check attached picture. BR Janar |
The Following 7 Users Say Thank You to janar_jk For This Useful Post: |
12-05-2008, 11:45 | #4 (permalink) |
Freak Poster Join Date: Jul 2005
Member: 159880 Status: Offline Thanks Meter: 60 | mate you have solution ? 7310 7,8,9 not working,sometime's 9 is pressing by it self...which of the two ic need to be change?thnk |
The Following User Says Thank You to arlbie For This Useful Post: |
12-12-2008, 20:01 | #7 (permalink) |
Member: 672494 Status: Offline Thanks Meter: 109 | put one wire from 7,8,9 to on jack last pin. same ic side from down is last pin Last edited by laddimobile; 12-12-2008 at 20:10. |
The Following 3 Users Say Thank You to laddimobile For This Useful Post: |
01-03-2009, 14:15 | #10 (permalink) |
No Life Poster Join Date: Apr 2005 Location: POLSKA Biesy... Age: 40
Member: 133762 Status: Offline Thanks Meter: 242 | change keypad flex... it is bug on this keypad bcoz if You hit the flex in place where track is going from lower layer to outer layer (a little dot) it'll work but it's only for a while... |
The Following User Says Thank You to piracik For This Useful Post: |
03-04-2009, 16:11 | #12 (permalink) |
No Life Poster Join Date: Nov 2007 Location: Hum Aapke Dil Mein Age: 38
Member: 637860 Status: Offline Sonork: 100.1605309 Thanks Meter: 996 | verry verry thankssir good job ........................... |
The Following User Says Thank You to Rizwan ch08 For This Useful Post: |
03-04-2009, 21:23 | #13 (permalink) |
Crazy Poster Join Date: Mar 2003 Location: Hungary Age: 41
Member: 24583 Status: Offline Thanks Meter: 25 | Hi! No change IC, just make this solution! It work, tested by me Sorry for bad photo! Br.udus |
The Following 10 Users Say Thank You to Dudus For This Useful Post: |
03-05-2009, 00:06 | #14 (permalink) |
Freak Poster Join Date: Nov 2005
Member: 195855 Status: Offline Thanks Meter: 26 | Here is the solution search first before post http://forum.gsmhosting.com/vbb/showthread.php?t=623748 |
The Following 3 Users Say Thank You to seny85 For This Useful Post: |
6700c keypad problem | luyanda | Nokia Hardware & Hardware Repair | 20 | 04-09-2014 10:16 |
7310c keypad some keys not working | ashok_kumar459 | Nokia Hardware & Hardware Repair | 9 | 11-11-2009 09:19 |
nk 7310c keypad problem | zeeshan tayyab | Nokia Base Band 5 ( BB-5 ) | 0 | 06-20-2009 10:05 |
7310c keypad soloution | laddimobile | Nokia Hardware & Hardware Repair | 0 | 03-04-2009 20:52 |
7310c keypad | malta | Nokia Hardware & Hardware Repair | 3 | 10-20-2008 07:30 |
