06-10-2009, 08:02 | #1 (permalink) |
No Life Poster Join Date: Nov 2008 Location: Faisalabad pakistan
Member: 900083 Status: Offline Thanks Meter: 601 | 7610 after on just show nokia and restart continuesely |
06-10-2009, 08:39 | #4 (permalink) |
Insane Poster Join Date: May 2008
Member: 775682 Status: Offline Thanks Meter: 14 | format user area with UFS 3 1 of the solution Hi.. My case same like yours and I just format user area and the phone READY to USE.... but make it 4 times and all must be ok. my phone become like that becoz of viruses thru BT so maybe same like yours...maybe yah just small solution from the east..... |
06-10-2009, 08:44 | #5 (permalink) |
No Life Poster Join Date: May 2008 Location: MX-KEY is the BEST NOKIA TOOL
Member: 771795 Status: Offline Sonork: 771795 Thanks Meter: 120 | This problem creat for 2 reason 1. virus. 2. Flasher problem. So first flash with good file and do format. If same condition its 100% flasher problem. |
06-10-2009, 09:35 | #7 (permalink) |
No Life Poster Join Date: May 2007 Location: InsidE AndroiD Age: 37
Member: 503161 Status: Offline Sonork: 100.1584069 Thanks Meter: 473 | JUST do format user are on ufs soooooo simple3.... |
The Following User Says Thank You to azeem781986 For This Useful Post: |
06-10-2009, 10:28 | #8 (permalink) |
No Life Poster Join Date: Sep 2008 Location: BANGLADESH
Member: 852543 Status: Offline Thanks Meter: 2,338 | just format by hand press 3,* & green key(calling button) then power on the mobile |
The Following 2 Users Say Thank You to masum_sohel For This Useful Post: |
06-10-2009, 15:05 | #9 (permalink) |
Member: 900083 Status: Offline Thanks Meter: 601 | dear brother's set dont accept 3+8+ formating some time ago this set show a erre (startup failed contat retaler i format it and set work ok and now problem is strange i flash it but the problem is same here si logs JAF version 1.98.48 Detected PKEY: 00000000 Card life counter: 97.74% P-key nokia module version 01.02 Detected JAF INTERFACE version: 01.B1, Driver version: 40000, Library version: 30107 JAF DCT4/BB5 LOADERS DIR: C:\Program Files\ODEON\JAF\Flash\ JAF DCT4/BB5 PRODUCT DIR: C:\Program Files\Nokia\Phoenix\Products\ JAF USB LOADERS DIR: C:\Program Files\ODEON\JAF\FlashUSB\ JAF DCT3/DCTL LOADERS DIR: C:\Program Files\ODEON\JAF\Flash3\ FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE INI file .ini is missing. Continue searching for second ini type... Changing flashing settings... FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-51\RH51_52_67_68PE605220.C1 PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-51\RH51PE605220.02 CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Languages in ppm: English,French,German (Euro A) MCU: C:\Program Files\Nokia\Phoenix\Products\RH-51\RH51_52_67_68PE605220.C1 Booting phone... MCU ID: 0x1081 BOOT file: C:\Program Files\ODEON\JAF\Flash\w3_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x10D8 Boot is ready... FLASH ID0: 22F800EC <=> SAMSUNG (SEC) -> Type not in database Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10 FLASH ID1: 22F800EC <=> SAMSUNG (SEC) -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 10 FLASH ID2: 22FA00EC <=> SAMSUNG (SEC) -> K8S6415ETA Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 10 FLASH ID3: 00010000 <=> Flash -> not used Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0 First 16 bytes: C6 00 00 EA 75 01 00 EA 78 01 00 EA 7B 01 00 EA Flash ID is 0x22F800EC Flash loader is C:\Program Files\ODEON\JAF\Flash\w3_amd.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x7F10; Loader chk: ac Loader is ready... P-key nokia module version 01.02 MSID: 845262EE6A566EA8E5B7FE1255 MSID decoded: 3E4EBAF700C5E410A9000000 FAID: EFAF67077917AC5FDF94AD67 Operation took 0 minutes 24 seconds... Erasing... Found 4 interval(s) to erase Erasing area: 00000000 - 0000FFFF... Erasing area: 00010000 - 00FFFFFF... Erasing area: 02000000 - 0287FFFF... Erasing area: 02FC0000 - 02FEFFFF... Operation took 3 minutes 51 seconds... Writing... Perm. Data Restore OK Operation took 3 minutes 12 seconds... Restarting MCU... PPM: C:\Program Files\Nokia\Phoenix\Products\RH-51\RH51PE605220.02 Booting phone... MCU ID: 0x1081 BOOT file: C:\Program Files\ODEON\JAF\Flash\w3_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x10D8 Boot is ready... FLASH ID0: 22F800EC <=> SAMSUNG (SEC) -> Type not in database Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10 FLASH ID1: 22F800EC <=> SAMSUNG (SEC) -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 10 FLASH ID2: 22FA00EC <=> SAMSUNG (SEC) -> K8S6415ETA Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 10 FLASH ID3: 00010000 <=> Flash -> not used Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0 First 16 bytes: C6 00 00 EA 75 01 00 EA 78 01 00 EA 7B 01 00 EA Flash ID is 0x22F800EC Flash loader is C:\Program Files\ODEON\JAF\Flash\w3_amd.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x7F10; Loader chk: ac Loader is ready... P-key nokia module version 01.02 MSID: 84144D9195FE7A251DCF52D2AB MSID decoded: 3E4EBAF700C5E410AA000000 FAID: C42FF9421FDE874DA5691669 Operation took 0 minutes 23 seconds... Erasing PPM... Found 2 interval(s) to erase Erasing area: 00000000 - 0000FFFF... Erasing area: 02A00000 - 02C9FFFF... Operation took 0 minutes 24 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 22 seconds... Restarting MCU... Flashing Done! Operation took 8 minutes 42 seconds... After flash processing... Waiting for phone to boot... Reading... Failed! Aborting!...MCUVER |
06-11-2009, 16:06 | #12 (permalink) |
Member: 503161 Status: Offline Sonork: 100.1584069 Thanks Meter: 473 | bro flash your fone with this version rh-51_v7.0642.0 here is the link http://depositfiles.com/en/files/2201358 |
06-11-2009, 16:07 | #13 (permalink) |
3110c turn on then show nokia and turm off | khm050 | Nokia Hardware & Hardware Repair | 9 | 07-14-2010 03:27 |
Nokia 5800 - just shows Nokia and goes off | c1rca | Nokia Base Band 5 ( BB-5 ) | 7 | 08-20-2009 09:42 |
7610 just showing nokia solution there. | waji mobiles | Nokia Hardware & Hardware Repair | 15 | 11-06-2008 14:32 |
7610 just showing nokia | crackp0d | Nokia Hardware & Hardware Repair | 17 | 10-30-2008 14:02 |
6630 Just Shows Nokia At Start After Flashing With Jaf | sairat | J.A.F. By Jafsupport.com | 3 | 12-17-2007 10:43 |
