05-17-2008, 21:52 | #1 (permalink) |
Freak Poster Join Date: Jun 2005 Location: EGYPT Age: 53
Member: 157001 Status: Offline Sonork: 100.1585825 Thanks Meter: 45 | 7610 big probloem i have 7610,was contact retelair i rehot the user area ic then it work perfect then the color of the lcd was pink i try every think for the lcd data Like ic data and the converter not solved then i try to flash it again it give me this error. with ufx 1st Boot Ok, WD2, UPP: 1081 Fl0: 0x00000000-0x00FFFFFF,00ECDDFE,Sam K8S5615ETA Fl1: 0x02000000-0x02FFFFFF,00ECEEFE,Sam K8S5615ETA Fl2: 0x04000000-0x047FFFFF,00EC2250,Sam K8S6415ETB Algorithm: w3_amd_b.fia, Ver: 4.52.0 Algorithm Ok, MSID: 84C672F26CC9CF3284D93E1CAD Decoded MSID: 3E4EBAF7-008B81A3-A9000000 Encoded FAID: D6255948-90A0AABB-18454C6F Area1: 0x00000000-0x0000FFFF Erased, Time: 00:00 Area2: 0x00010000-0x00FFFFFF Erased, Time: 01:57 Area3: 0x02000000-0x0287FFFF Erased, Time: 01:03 Area4: 0x02FC0000-0x02FEFFFF Erased, Time: 00:01 Write Error: hDat 14, at: 0x00020000:08 Process Failed, Repowering Mobile with jaf Getting MCU ID MCU ID: 0x1081 FLASH ID0: DDFE00EC <=> SAMSUNG (SEC) -> Type not in database Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10 FLASH ID1: EEFE00EC <=> SAMSUNG (SEC) -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 10 FLASH ID2: 225000EC <=> SAMSUNG (SEC) -> K8S6415ETB Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 10 FLASH ID3: 00010000 <=> Flash -> not used Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0 First 16 bytes: C6 00 00 EA 75 01 00 EA 78 01 00 EA 7B 01 00 EA Checking RAM for ALGO... Algo is ready... Checking FAID calculation... P-key nokia module version 01.01 Done! Phone Restarted... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE INI file .ini is missing. Continue searching for second ini type... Changing flashing settings... FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-51\RH51_52_67_68PE706420.C1 PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-51\RH51PE706420.02 CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Languages in ppm: English,French,German (Euro A) Changing flashing settings... FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-51\RH51_52_67_68PE706420.C1 PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-51\RH51PE706420.12 CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Languages in ppm: English,Hebrew,Arabic (Hebrew) Backing up PM Field 208 as RPL... Setting local mode... Failed! Aborting! Failed to backup imei... MCU: C:\Program Files\Nokia\Phoenix\Products\RH-51\RH51_52_67_68PE706420.C1 Booting phone... MCU ID: 0x1081 BOOT file: C:\Program Files\ODEON\JAF\Flash\w3_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x10D8 Boot is ready... FLASH ID0: DDFE00EC <=> SAMSUNG (SEC) -> Type not in database Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10 FLASH ID1: EEFE00EC <=> SAMSUNG (SEC) -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 10 FLASH ID2: 225000EC <=> SAMSUNG (SEC) -> K8S6415ETB Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 10 FLASH ID3: 00010000 <=> Flash -> not used Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0 First 16 bytes: C6 00 00 EA 75 01 00 EA 78 01 00 EA 7B 01 00 EA Flash ID is 0xDDFE00EC Flash loader is C:\Program Files\ODEON\JAF\Flash\w3_amd.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x7F10; Loader chk: 4 Loader is ready... P-key nokia module version 01.01 MSID: 84C672F26CC9CF3284D93E1CAD MSID decoded: 3E4EBAF7008B81A3A9000000 FAID: 916B21B5E127E0B03C9137AB Operation took 0 minutes 24 seconds... Erasing... Found 4 interval(s) to erase Erasing area: 00000000 - 0000FFFF... Erasing area: 00010000 - 00FFFFFF... Erasing area: 02000000 - 0287FFFF... Erasing area: 02FC0000 - 02FEFFFF... Operation took 2 minutes 56 seconds... Writing... Error cmd: 14! Addr: 00020000 so i try to reball the two ics not solved tring reball the upp not solved trying to rehot the ram also not solved and now the phone is dead so would you can help me what can i do? thanks in advance |
05-17-2008, 22:06 | #3 (permalink) |
Junior Member Join Date: Oct 2007
Member: 617410 Status: Offline Thanks Meter: 0 | اما بلنسبة الى Erasing area: 00000000 - 0000FFFF... Erasing area: 00010000 - 00FFFFFF... Erasing area: 02000000 - 0287FFFF... Erasing area: 02FC0000 - 02FEFFFF... Operation took 2 minutes 56 seconds... Writing... فادى مشكلة فى اى سى الفلاش |
05-18-2008, 06:45 | #4 (permalink) |
No Life Poster Join Date: Sep 2007 Location: Jalandhar Age: 39
Member: 580966 Status: Offline Sonork: 100.1590311 Thanks Meter: 725 | @tayseer Skip Bt & try flashing. hope your problem will be solved. |
The Following User Says Thank You to KK Mobile For This Useful Post: |
1110I-1112 LCD CONTRAST Big Probloem | el-safwa | MT-BOX | 7 | 12-15-2007 08:20 |
CONTRAST 1110 Big Probloem??????????? | GSMLover2010 | Universalbox | 29 | 11-24-2007 15:39 |
7610 big problem | indian mobiles | Nokia Hardware & Hardware Repair | 10 | 04-04-2007 20:47 |
