10-15-2006, 19:08 | #3 (permalink) |
Freak Poster Join Date: Dec 2005 Location: UEM
Member: 207453 Status: Offline Thanks Meter: 14 | Dear loexman, plz.. always give complete fone history with ur question so you wil get right answer,. it fell on ground or water damage, new box fone??? your fone is able to recive and make call just blank lcd?? if yes 1) check Display 2) check display connector all voltages if all connector points are not ok then resolder or if nesseary change it very carefully.. 3) check display ic reball it if necessary change it with orginal one find out attachments that wil help u lot to solve ur problem if fone is not able to make or recive call then just blank screen?? 1) if fone can detect and can get inform thru UFS then check IMEI is ok or imei ??????? 2) if imei ok flash fone with latest version 2) format user area 4) full factory settings reset user lock etc.. still not done ? erase flash and again flash fone with latest version write good pm format user area full factory setting reset user lock etc.. and check if stil probs send me result where u r getting error with more details.. if your fone imei is ???????? that means ur UEM damaged you wil need to replace it but you dont try to play with UEM til you conform about that,, you may damage ur PCB so do carefully all things and best of luck.. people wil help u if u wil help them by giving fone history in ur question Regards abdulrahman |
The Following User Says Thank You to abdulrahman For This Useful Post: |
Nokia 7610 Blank Display Network Ok | san9090 | WD2 & APE (Symbian Phones) | 5 | 09-20-2008 22:57 |
7610 blank display | lohith03 | Nokia Hardware & Hardware Repair | 2 | 05-13-2008 10:50 |
7610 blank display | naseer_10_1980 | Nokia Hardware & Hardware Repair | 5 | 06-01-2007 05:46 |
