7610 contact retailer need solution for contact retailer? |
frist full erase and flash ,ok pm,unlock,factory settings,file sys format then cheak it post result good luck bro |
Manualy format the unit or format user area with ufs,jaf or any box which you have. ;) |
tnx a lot bro, i resolved the problem |
thank u for reply....................... |
Just Format... * + 3 + Send Button + Power Button................ |
100~~~~ teste by me 1 Attachment(s) change boot ic and 100% set is ok and try this meathod |
Yes bro Manually format the phone. U r set will be OK Post result. |
this paroblam is uem |
why not do self test first??????????????????????? ---- Byte |
one perfect solution for 7610 contact retailer = "format user area" in twister & ufs box. |
try formatting manually if not ok then only try my trick just try flashing ur phone in MT-BOX in any Nokia mobiles if u r getting Contact Retailer try flashing it on MT-BOX ur problem will be solved 1110000%.... REGARDS MAIMOON MOBILES |
