04-15-2006, 09:13 | #1 (permalink) |
Major Poster Join Date: Sep 2005 Age: 56
Member: 180714 Status: Offline Thanks Meter: 0 | 7610 dead 1st Boot Ok, WD2, UPP: 1081 Fl0: 0x00000000-0x00FFFFFF,00EC22F8,Sam K8S2815ET Fl1: 0x02000000-0x02FFFFFF,00EC22F8,Sam K8S2815ET Fl2: 0x04000000-0x047FFFFF,00EC22FA,Sam K8S6415ET Fl3: 0x06000000-0x067FFFFF,00800081, Algorithm: w3_amd_b.fia, Ver: 4.49.0 Algorithm Ok, MSID: 840A97598F7EA4B9E91A0DC507 Decoded MSID: 3E4EBAF7-0050CD27-A9000000 Encoded FAID: ED37CBB0-118EC493-DB5C56C5 Area1: 0x00000000-0x0000FFFF Erased, Time: 0:00 Area2: 0x00010000-0x00FFFFFF Erased, Time: 0:07 Area3: 0x02000000-0x029FFFFF Erased, Time: 0:04 Area4: 0x02FC0000-0x02FEFFFF Erased, Time: 0:00 Write Error: hDat 14, at: 0x00000000:08 Process Failed, Repowering Mobile What wrong and how to fit it |
05-25-2006, 05:05 | #3 (permalink) |
Freak Poster Join Date: Dec 2004
Member: 96236 Status: Offline Thanks Meter: 7 | have you solved your problem? i got same 7610 problem too. hdat write error. pls share if you happen to solfe it, ill try help if i work it out. btw i rework 2 flash , 1 sram, uem and upp, same problem still. any clue?> beeega |
07-25-2006, 05:02 | #6 (permalink) | |
Freak Poster Join Date: Aug 2004
Member: 77254 Status: Offline Thanks Meter: 9 | Quote:
did you find any open track between IC flash and UPP? or you just re-ball the IC? | |
7610 Dead-flashing Ok-in It Local Mode Failed-replaced Uem-still Dead | zonetrichur | Nokia Hardware & Hardware Repair | 26 | 03-27-2010 08:06 |
7610 dead,flashing ok,still dead | Vcell | WD2 & APE (Symbian Phones) | 2 | 08-10-2008 11:57 |
7610 dead | dogandbone | Twisterflasher | 4 | 12-07-2005 14:54 |
7610 dead | techman | Nokia Hardware & Hardware Repair | 6 | 12-06-2004 09:59 |
nokia 7610 dead | ray_5572 | WD2 & APE (Symbian Phones) | 4 | 11-11-2004 06:37 |
