12-30-2006, 18:10 | #1 (permalink) |
No Life Poster Join Date: Mar 2006 Location: india
Member: 239168 Status: Offline Thanks Meter: 104 | 7610 Dead-flashing Ok-in It Local Mode Failed-replaced Uem-still Dead I FIRST TRIED IN UFS THE ERASE METHOD. 1- with ufs box start to erase manual this adress start: 00000000 end: 00FFFFFF start: 02000000 end: 02FFFFFF start: 04000000 end: 047FFFFF this 3 adress will eras the 3 flash's and u will not lost ur phone imei 2- with ufs again erase start: 00010000 end: 0000FFFF start: 02000000 end: 00FFFFFF start: 02FC0000 end: 0286FFFF start: 02A00000 end: 0000FFFF 3- flash ur phone with latest firmware 4- write full pm to ur phone 5- unlock and format user area FOURTH STEP FAILED.ERROR MESSAGE IS "Init Local Mode Failed Write PM Failed".SO STILL MY SET IS DEAD. FLASHING LOGS IN UFS AS BELOW "1st Boot Ok, WD2, UPP: 1081 Fl0: 0x00000000-0x00FFFFFF,00EC22F8,Sam K8S2815ET Fl1: 0x02000000-0x02FFFFFF,00EC22F8,Sam K8S2815ET Fl2: 0x04000000-0x047FFFFF,00EC22FA,Sam K8S6415ET Algorithm: w3_amd_b.fia, Ver: 4.49.0 Algorithm Ok, MSID: 845BE6ADDD5FF01ADCDCA4E68A Decoded MSID: 3E4EBAF7-00871652-A9000000 Encoded FAID: AF2485C0-D3D5A664-EAC5F62A Area1: 0x00000000-0x0000FFFF Erased, Time: 00:00 Area2: 0x00010000-0x00FFFFFF Erased, Time: 02:37 Area3: 0x02000000-0x029FFFFF Erased, Time: 01:37 Area4: 0x02FC0000-0x02FEFFFF Erased, Time: 00:01 MCU Flashing Completed, Time: 04:58 Area1: 0x00000000-0x0000FFFF Erased, Time: 00:00 Area2: 0x02B00000-0x02D9FFFF Erased, Time: 00:25 PPM Flashing Completed, Time: 00:30 Flashing Completed, Rebooting Mobile"""""" THEN I TRIED IN JAF.LOGS AS BELOW MCU: D:\Program Files\Nokia\Phoenix\products\RH-51\RH51_67PE605250.C2 Booting phone... MCU ID: 0x1081 BOOT file: D:\Program Files\ODEON\JAF\Flash\w3_2nd.fia Loader version: 04.39.00 -> Revision: 0007 Boot size is 0x1088 Boot is ready... FLASH ID0: EC00F822 -> ST Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10 FLASH ID1: EC00F822 -> ST Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 10 FLASH ID2: EC00FA22 -> ST Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 10 FLASH ID3: 00000100 -> NOT USED Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0 First 16 bytes: C6 00 00 EA 75 01 00 EA 78 01 00 EA 7B 01 00 EA Flash ID is 0x22F800EC Flash loader is D:\Program Files\ODEON\JAF\Flash\w3_amd.fia Loader version: 04.39.00 -> Revision: 0007 Loader size is 0x7E48; Loader chk: ff Loader is ready... P-key nokia module version 01.00 MSID: 845BE6ADDD5FF01ADCDCA4E68A MSID decoded: 3E4EBAF700871652A9000000 FAID: 0FBD87E3DE9B0C574FEC7AAC Operation took 0 minutes 22 seconds... Erasing... Found 4 interval(s) to erase Erasing area: 00000000 - 0000FFFF... Erasing area: 00010000 - 00FFFFFF... Erasing area: 02000000 - 029FFFFF... Erasing area: 02FC0000 - 02FEFFFF... Operation took 4 minutes 7 seconds... Writing... Perm. Data Restore OK Operation took 3 minutes 32 seconds... Restarting MCU... PPM: D:\Program Files\Nokia\Phoenix\products\RH-51\RH51PE605250.31 Booting phone... MCU ID: 0x1081 BOOT file: D:\Program Files\ODEON\JAF\Flash\w3_2nd.fia Loader version: 04.39.00 -> Revision: 0007 Boot size is 0x1088 Boot is ready... FLASH ID0: EC00F822 -> ST Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10 FLASH ID1: EC00F822 -> ST Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 10 FLASH ID2: EC00FA22 -> ST Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 10 FLASH ID3: 00000100 -> NOT USED Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0 First 16 bytes: C6 00 00 EA 75 01 00 EA 78 01 00 EA 7B 01 00 EA Flash ID is 0x22F800EC Flash loader is D:\Program Files\ODEON\JAF\Flash\w3_amd.fia Loader version: 04.39.00 -> Revision: 0007 Loader size is 0x7E48; Loader chk: ff Loader is ready... P-key nokia module version 01.00 MSID: 841484EF977DAFFBBD5F619532 MSID decoded: 3E4EBAF700871652A8000000 FAID: 534E7EB0DC36ACB085EA639C Operation took 0 minutes 22 seconds... Erasing PPM... Found 2 interval(s) to erase Erasing area: 00000000 - 0000FFFF... Erasing area: 02B00000 - 02D6FFFF... Operation took 0 minutes 23 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 21 seconds... Restarting MCU... Flashing Done! Operation took 9 minutes 12 seconds... After flash processing... Waiting for phone to boot... Failed! Aborting! SO IN JAF ALSO DID NOT SET ON. THEN I TRIED IN MTBOX.SEVERAL TIMES TRIED-CAN NOT FLASH Processing File: RH51_67PE605250.C2 Boot... FAILED TO BOOT PHONE!!! Make sure that phone is connected. WHY IN MTBOX CAN NOT FLASH?SAME CABLE USED IN UFS,JAF,MTBOX CAN NOT FLASH-THATS NOT MY PROBLEM-I WANT TO KNOW WHICH IC IN MY SET IS FAULTY?I THINK UEM-I REPLACED UEM-STILL SAME ERROR MESSAGE AS ABOVE. HAVE U GOT ANY IDEA OF MY PROBLEM? THANK U |
01-01-2007, 07:07 | #10 (permalink) | |
No Life Poster Join Date: May 2006 Location: U wont beleive Age: 43
Member: 275631 Status: Offline Thanks Meter: 408 | Quote:
01-01-2007, 12:41 | #12 (permalink) | |
Freak Poster Join Date: Dec 2004 Age: 55
Member: 95745 Status: Offline Thanks Meter: 10 | Quote:
SHAHI | |
01-01-2007, 18:01 | #15 (permalink) |
Member: 275631 Status: Offline Thanks Meter: 408 | did u change the ic .... the jumper should b applyed without that ic... the fon will 100% boot... even without that ic.... as i write above change the ic.... OR REMOVE it then apply jumper. |
E66 flash ok but no local mode & no ui seting | somratjisan | Nokia Base Band 5 ( BB-5 ) | 0 | 02-06-2010 10:15 |
2626 rm-291 dead, flashed already but can't local mode | ru_dee | Nokia Digital Core Technology 4 ( DCT-4 ) | 6 | 09-17-2009 03:08 |
1100 flashing ok but can't local mode ui fauld. | debmobile | Nokia Hardware & Hardware Repair | 7 | 12-21-2008 06:11 |
3110c dead-flashing ok-but in it local mode failed-which ic? | zone2 | Nokia Base Band 5 ( BB-5 ) | 4 | 11-18-2008 06:36 |
...:: 1100 flashing OK Not show LOCAL MODE ::... | amol_sm | Nokia Digital Core Technology 4 ( DCT-4 ) | 6 | 04-28-2007 21:25 |
