09-10-2008, 20:35 | #1 (permalink) |
Junior Member Join Date: Jul 2008
Member: 806344 Status: Offline Thanks Meter: 8 | 7610 Failed! Aborting!...MCUVER MCU ID: 0x1081 FLASH ID0: DDFE00EC <=> SAMSUNG (SEC) -> Type not in database Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10 FLASH ID1: EEFE00EC <=> SAMSUNG (SEC) -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 10 FLASH ID2: 225000EC <=> SAMSUNG (SEC) -> K8S6415ETB Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 10 FLASH ID3: 00010000 <=> Flash -> not used Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0 First 16 bytes: C6 00 00 EA 75 01 00 EA 78 01 00 EA 7B 01 00 EA Checking RAM for ALGO... Algo is ready... Checking FAID calculation... MCU: C:\Program Files\Nokia\Phoenix\Products\RH-51\RH51_52_67_68PE706420.C1 Booting phone... Phone didn't answer with TX line low after UEM reset! Causes: 1. put a 27-33 pico capacitor in connector b/w mbus-gnd. 2. UEM damaged -> replace uem. MCU ID: 0xDDDD This MCU ID is not supported in chosen flash file... Error booting phone... MCU: C:\Program Files\Nokia\Phoenix\Products\RH-51\RH51_52_67_68PE706420.C1 Booting phone... Phone didn't answer with TX line low after UEM reset! Causes: 1. put a 27-33 pico capacitor in connector b/w mbus-gnd. 2. UEM damaged -> replace uem. MCU ID: 0xDDDD This MCU ID is not supported in chosen flash file... Error booting phone... MCU: C:\Program Files\Nokia\Phoenix\Products\RH-51\RH51_52_67_68PE706420.C1 Booting phone... MCU ID: 0x1081 BOOT file: C:\Program Files\ODEON\JAF\Flash\w3_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x10D8 Boot is ready... Error in CHK... Error Loading loader! MCU: C:\Program Files\Nokia\Phoenix\Products\RH-51\RH51_52_67_68PE706420.C1 Booting phone... Phone didn't answer with TX line high after power on! Causes: 1. Phone don't power on -> Check cable 2. TX pin from phone don't make contact -> Check cable 3. UPP damaged -> change UPP MCU ID: 0xAAAA This MCU ID is not supported in chosen flash file... Error booting phone... MCU: C:\Program Files\Nokia\Phoenix\Products\RH-51\RH51_52_67_68PE706420.C1 Booting phone... Phone didn't answer with TX line high after power on! Causes: 1. Phone don't power on -> Check cable 2. TX pin from phone don't make contact -> Check cable 3. UPP damaged -> change UPP MCU ID: 0xAAAA This MCU ID is not supported in chosen flash file... Error booting phone... MCU: C:\Program Files\Nokia\Phoenix\Products\RH-51\RH51_52_67_68PE706420.C1 Booting phone... Phone didn't answer with TX line high after power on! Causes: 1. Phone don't power on -> Check cable 2. TX pin from phone don't make contact -> Check cable 3. UPP damaged -> change UPP MCU ID: 0xAAAA This MCU ID is not supported in chosen flash file... Error booting phone... MCU: C:\Program Files\Nokia\Phoenix\Products\RH-51\RH51_52_67_68PE706420.C1 Booting phone... MCU ID: 0x1081 BOOT file: C:\Program Files\ODEON\JAF\Flash\w3_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x10D8 Boot is ready... FLASH ID0: DDFE00EC <=> SAMSUNG (SEC) -> Type not in database Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10 FLASH ID1: EEFE00EC <=> SAMSUNG (SEC) -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 10 FLASH ID2: 225000EC <=> SAMSUNG (SEC) -> K8S6415ETB Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 10 FLASH ID3: 00010000 <=> Flash -> not used Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0 First 16 bytes: C6 00 00 EA 75 01 00 EA 78 01 00 EA 7B 01 00 EA Flash ID is 0xDDFE00EC Flash loader is C:\Program Files\ODEON\JAF\Flash\w3_amd.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x7F10; Loader chk: 4 Loader is ready... P-key nokia module version 01.02 MSID: 84A0C6063A960448FB9CB89DF9 MSID decoded: 3E4EBAF70089A40CA9000000 FAID: 276F2749CCECCB4DD6005AD8 Operation took 0 minutes 22 seconds... Erasing... Found 4 interval(s) to erase Erasing area: 00000000 - 0000FFFF... Erasing area: 00010000 - 00FFFFFF... Erasing area: 02000000 - 0287FFFF... Erasing area: 02FC0000 - 02FEFFFF... Operation took 2 minutes 59 seconds... Writing... Perm. Data Restore OK Operation took 3 minutes 2 seconds... Restarting MCU... PPM: C:\Program Files\Nokia\Phoenix\Products\RH-51\RH51PE706420.03 Booting phone... MCU ID: 0x1081 BOOT file: C:\Program Files\ODEON\JAF\Flash\w3_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x10D8 Boot is ready... FLASH ID0: DDFE00EC <=> SAMSUNG (SEC) -> Type not in database Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10 FLASH ID1: EEFE00EC <=> SAMSUNG (SEC) -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 10 FLASH ID2: 225000EC <=> SAMSUNG (SEC) -> K8S6415ETB Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 10 FLASH ID3: 00010000 <=> Flash -> not used Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0 First 16 bytes: C6 00 00 EA 75 01 00 EA 78 01 00 EA 7B 01 00 EA Flash ID is 0xDDFE00EC Flash loader is C:\Program Files\ODEON\JAF\Flash\w3_amd.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x7F10; Loader chk: 4 Loader is ready... P-key nokia module version 01.02 MSID: 84E7035A4047CEA90594157A15 MSID decoded: 3E4EBAF70089A40CAA000000 FAID: BA63CAE92507E29762759FD3 Operation took 0 minutes 22 seconds... Erasing PPM... Found 2 interval(s) to erase Erasing area: 00000000 - 0000FFFF... Erasing area: 02A00000 - 02CAFFFF... Operation took 0 minutes 19 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 20 seconds... Restarting MCU... Flashing Done! Operation took 7 minutes 28 seconds... After flash processing... Waiting for phone to boot... Reading... Failed! Aborting!...MCUVER |
09-10-2008, 20:51 | #3 (permalink) | |
No Life Poster Join Date: Sep 2007 Location: :::::::EMIRATES:::::::
Member: 591669 Status: Offline Sonork: 110011 Thanks Meter: 687 | Quote:
7610 Failed! Aborting!...MCUVER | namdonganh | WD2 & APE (Symbian Phones) | 17 | 03-11-2009 21:51 |
7610 Failed! Aborting!...MCUVER | Xhimieurocel | Nokia Digital Core Technology 4 ( DCT-4 ) | 4 | 08-23-2008 19:37 |
