Old 01-29-2008, 18:05   #1 (permalink)
Member: 63691
Thanks Meter: 114
7610 flashing error
7610 came to me with nokia hanging,replaced boot ic fone was ok.
but sterted to go off every 10 minutes,flashed with latest version,same problem.then reballed flash and ram,now when connected to JAF it shows following log
Changing flashing settings...
FILES SET FOR FLASHING:
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-51\RH51_52_67_68PE706420.C1
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-51\RH51PE706420.03
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Languages in ppm: English,Arabic,French (Arabic)
MCU: C:\Program Files\Nokia\Phoenix\Products\RH-51\RH51_52_67_68PE706420.C1
Booting phone...
MCU ID: 0x1081
BOOT file: C:\Program Files\ODEON\JAF\Flash\w3_2nd.fia
Loader version: 04.40.00 -> Revision: 0007
Boot size is 0x10A8
Boot is ready...
FLASH ID0: 00000100 -> NOT USED Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 0
FLASH ID1: 00000100 -> NOT USED Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0
FLASH ID2: 00000100 -> NOT USED Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 0
FLASH ID3: 00000100 -> NOT USED Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0
First 16 bytes: 00 00 01 00 02 00 03 00 04 00 05 00 06 00 07 00
Flash ID is 0x00010000
Flash loader is C:\Program Files\ODEON\JAF\Flash\w3_amd.fia
Loader size is 0x7EA8; Loader chk: eb
Loader is ready...
P-key nokia module version 01.00
MSID: 8478E4CAB1AA0B297B6B694DA5
MSID decoded: 3E4EBAF700886E82A9000000
FAID: 70D27F9598E0610B3803F80F
Operation took 0 minutes 24 seconds...
Erasing...
Found 4 interval(s) to erase
Erasing area: 00000000 - 0000FFFF...
Erasing area: 00010000 - 00FFFFFF...
Erasing area: 02000000 - 0287FFFF...
Erasing area: 02FC0000 - 02FEFFFF...
Operation took 0 minutes 3 seconds...
Writing...
Error cmd: 14!
Addr: 00000000
sajidmirza
Old 01-29-2008, 23:42   #2 (permalink)
milkyctg's Avatar
Member: 56855
Thanks Meter: 77
Replace the UEM, reflash ur phone, rebuild imei with asic5 rpl and finally unlock the phone.
Old 01-30-2008, 06:37   #3 (permalink)
sajidmirza's Avatar
Member: 256461
Sonork: 100.1608049
Thanks Meter: 90
thanx for ur response,i will try and post result.
sajidmirza.
Old 01-30-2008, 07:44   #4 (permalink)
shama's Avatar
Member: 333037
Sonork: 100.1611244
Thanks Meter: 77
here all flash ids incarect .change upp or rebol upp you will seccess
Old 01-30-2008, 08:38   #5 (permalink)
joni_yang's Avatar
Member: 560754
Thanks Meter: 289
Booting phone...
MCU ID: 0x1081
Boot size is 0x10A8
Boot is ready...
Loader is ready...
Erasing...
Writing...
Error cmd: 14!
Addr: 00000000
sajidmirza
dear,try to replaced/changed flash ic if not ok replaced/changed upp...
good luck...
Old 02-20-2008, 19:28   #6 (permalink)
Member: 276150
Thanks Meter: 75
Booting phone...
MCU ID: 0x1081
Loader version: 04.45.00 -> Revision: 0007
Boot size is 0x10D8
Boot is ready...
FLASH ID0: EC00FEDD -> ST Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10
FLASH ID1: EC00FEEE -> ST Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 10
FLASH ID2: EC005022 -> ST Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 10
FLASH ID3: EC00FEDD -> ST Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 10
First 16 bytes: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Flash ID is 0xDDFE00EC
Loader size is 0x7F18; Loader chk: d4
Loader is ready...
MSID: 84B6E094C8412DDFF37578D6EA
MSID decoded: 3E4EBAF7001BDFFBA9000000
FAID: 60A1C5AE1C5B6CA71F40ED34
Erasing...
Erasing area: 02000000 - 029FFFFF...
Operation took 3 minutes 19 seconds...
Writing...
Error cmd: 14!
Addr: 02000000
can some one tell me what is the problem
Old 02-20-2008, 21:23   #7 (permalink)
saiftc2's Avatar
Member: 231662
Sonork: 1607488
Thanks Meter: 390
hi men>>>>>>>>>> what r u do?????
if 4 addresses appear that due to:
1- Cristal ic between Big flash and upp (most cause)
2- Flashes (remove one by one) and compare
3- upp or uem (less commone)
if you replace big flash by another (orginal big flash) you must remove cristal and capacitor below it and put R (or jumper) below capacitor (removed)>>>
GsmJoman
Tc
Old 02-20-2008, 22:05   #8 (permalink)
Member: 143156
Thanks Meter: 95
GsmJoman
Tc
nice my friend
keep it up
Old 02-21-2008, 03:52   #9 (permalink)
agent_lia's Avatar
Member: 291404
Thanks Meter: 58
sir i think youre problem is ram ic i did it before and 100% work for me.....hope it can help you
Old 02-24-2008, 09:40   #10 (permalink)
Member: 276150
Thanks Meter: 75
I am really thankful to all of you for clearing my doubt ...
I will check whts wrog
Old 02-24-2008, 17:25   #11 (permalink)
saiftc2's Avatar
Member: 231662
Sonork: 1607488
Thanks Meter: 390
@ adelking
thank .. my friend
GsmJoman
Tc
Old 02-25-2008, 15:16   #12 (permalink)
Sagitarious's Avatar
Member: 615730
Thanks Meter: 256
very nice brother.................
Old 08-01-2018, 19:11   #13 (permalink)
Member: 1401478
Sonork: alaa
Thanks Meter: 3
hi my frineds i need Arabic flash
rh-51 v7.0642 plz
Page generated in 0.20199 seconds with 10 queries
