02-20-2009, 12:16 | #1 (permalink) |
No Life Poster Join Date: Oct 2005 Location: lahore
Member: 188574 Status: Offline Sonork: 100.1590742 Thanks Meter: 751 | 7610 flashing ok imei ???????? I TRIED TO FLASH WITH RH 67 VERSION FILES BECAUSE I WAS THINKING THIS WAS 6670 . BUT WITH THAT ALWAYS SHOWING MCU VERSION ERROR. THEN I TRIED WITH RH 51 VERSION IN THAT PHONE COMPLETED FLASHING BUT LAST FOUND THAT IMEI BECOME ???????? I TRIED TO READ UEM ITS IMEI OK. SHOWING AND ITS NOT CHANGING. NOW PROBLEM IS THIS IF I MAKE ASK FILES IN THAT I NEED IMEI (WHICH I WILL USE AS SHOWN IN UEM IMEI) 2- SECONDLY I NEED PRODUCT CODE THAT I DONT HAVE BECAUSE I GOT ONLY PCB. 3- I NEED TO ASIC 5 I NEED TO KNOW WITHOUT PRODUCT CODE (OR I CAN USE ANY OF THE PRODUCT CODE AND MAKE ASK FILE) CAN MAKE ASK FILE AND IS THAT RPL WILL BE OK FOR THAT OR NOT... OR ANY OTHER WAY TO GET BACK IMEI FROM FLASH . THAT I THINK ERASED DURING ERASE ADDRESS. PLZ I KNOW THIS IS OLD TOPIC. BUT I SEARCH . I COULD'T GET ANY SOLUTION. SPECIALLY FOR ASK FILE WITHOUT PRODUCT CODE. IS THAT MAKE ANY EFFECT ON RPL CALCULATION. THANKS. |
02-20-2009, 14:26 | #3 (permalink) |
Member: 188574 Status: Offline Sonork: 100.1590742 Thanks Meter: 751 | here is the log from jaf Thanks for your reply . I am posting here with manual option reading UEM is showing like this. MCU ID: 0x1081 Sending algo... Algo is ready... P-key nokia module version 01.02 Reading... UEM IMEI: 35538200936334X and here i coult't find product code. BR Naveed Yousaf |
02-20-2009, 15:39 | #6 (permalink) |
Member: 188574 Status: Offline Sonork: 100.1590742 Thanks Meter: 751 | Thanks a lot for your suggestions I have ufs and jaf. But i want to know is that necessary exect product code to calculate RPL because even in Jaf i can get ask when i put product code from other phone. Is that make any difference in RPL calculation. If we will not use exect Product Code. and That Product code also stored in UEM . Thanks again for all brothers. BR Naveed Yousaf |
7610 flash ok, but set not on and not show nokia after flashing | kashif_khatri | WD2 & APE (Symbian Phones) | 3 | 08-05-2009 08:42 |
7610 flash ok show nokia ok | irfaN_vu | Nokia Hardware & Hardware Repair | 5 | 01-03-2008 14:19 |
7610 flashing ok unable to on | ashok_kumar459 | WD2 & APE (Symbian Phones) | 50 | 04-24-2007 11:53 |
nokia 7610 flash ok pwoer ok | ahmed nokia | WD2 & APE (Symbian Phones) | 3 | 09-11-2006 22:39 |
7610 flash ok but dont switch on | faigsm | Nokia Hardware & Hardware Repair | 1 | 10-24-2005 23:30 |
