Old 01-12-2008, 23:39   #1 (permalink)
Member: 63030
Thanks Meter: 8
7610 flashing problem
My 7610 not flashing with ufs3 ,it shows this error ...what is the problem,please help.
1st Boot Ok, WD2, UPP: 1081
Fl0: 0x00000000-0x00FFFFFF,00EC20F8,Sam No Name
Fl1: 0x02000000-0x02FFFFFF,00EC20F8,Sam No Name
Fl2: 0x04000000-0x04FFFFFF,00EC2050,Sam No Name
FLASH DEVICE NOT SUPPORTED
Check Product, Use newer Flash Update Pack
Bad Algorithm File: w3_amd_b.fia
2nd Boot Error:
Error Data1:
00000000: 9F 04 04 00 EC 00 F8 20 00 00 11 00 00 00 02 EC ....... ........
00000010: 00 F8 20 00 00 11 00 00 00 04 EC 00 50 20 00 00 .. .........P ..
00000020: 21 01 00 00 06 00 00 01 00 00 00 00 00 00 00 FF !...............
00000030: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 52 ...............R
Error Data2:
00000000: 11 11 11 11 00 00 00 00 00 00 00 00 00 00 00 00 ................
00000010: 00 00 11 00 00 00 04 EC 00 50 20 00 00 21 01 00 .........P ..!..
00000020: 00 06 00 00 01 00 00 00 00 00 00 00 FF FF FF FF ................
00000030: FF FF FF FF FF FF FF FF FF FF FF FF 52 D3 72 00 ............R.r.
Before taking screenshot, expand this window !
Process Failed, Repowering Mobile
Old 01-13-2008, 07:09   #2 (permalink)
Member: 480959
Thanks Meter: 49
brother look carfully the log the flash id of the flashes are not shown for that u have to reball the cpu if not solve then reball flash ics. ur problem will solve.
Old 01-13-2008, 07:11   #3 (permalink)
stan1comm's Avatar
Member: 609952
Sonork: 100.1574492
Thanks Meter: 154
if you have a anther tool for nokia try on it tell us
www.stan1comm.com
Old 01-13-2008, 07:42   #4 (permalink)
omer farooq bha's Avatar
Member: 522050
Thanks Meter: 62
2nd Boot Error:
Error Data1:
Error Data2:
reheat the rams if not solved reball rams its ok
Old 01-13-2008, 09:10   #5 (permalink)
Member: 390359
Thanks Meter: 30
try with another pc, another box, another cable... it is may be software problem with fias.
if problem is same with another box, then reball or change upp.
Old 01-13-2008, 10:14   #6 (permalink)
Member: 256214
Thanks Meter: 10
just rehot the CPU it will work 100%
Old 01-14-2008, 10:50   #7 (permalink)
manyosa's Avatar
Member: 271974
Thanks Meter: 97
Reheat flash ic and try to reflash it
Old 01-14-2008, 13:23   #8 (permalink)
jolie's Avatar
Member: 570581
Thanks Meter: 223
change flash ic 100/100 work
Old 01-14-2008, 15:10   #9 (permalink)
Member: 256214
Thanks Meter: 10
it CPU just rehot the CPU
Old 01-14-2008, 15:11   #10 (permalink)
Member: 256214
Thanks Meter: 10
its CPU just rehot the CPU
Old 01-15-2008, 13:43   #11 (permalink)
Member: 63030
Thanks Meter: 8
I changed the cpu and ram ic now its flashing like this...
ufs result...
Fl0: 0x00000000-0x00FFFFFF,00EC22F8,Sam K8S2815ETA
Fl1: 0x02000000-0x02FFFFFF,00EC22F8,Sam K8S2815ETA
Fl2: 0x04000000-0x047FFFFF,00EC2250,Sam K8S6415ETB
Algorithm: w3_amd_b.fia, Ver: 4.68.0
Algorithm Ok, MSID: 841891422419FB399933CA4588
Decoded MSID: 3E4EBAF7-0014915C-A9000000
Encoded FAID: 5F4FE63F-85FA4A36-BC116E10
Area1: 0x00000000-0x0000FFFF Erased, Time: 00:00
Area2: 0x00010000-0x00FFFFFF Erased, Time: 02:38
Area3: 0x02000000-0x0287FFFF Erased, Time: 01:28
Area4: 0x02FC0000-0x02FEFFFF Erased, Time: 00:02
Write Error: hDat 14, at: 0x02000000:08
Process Failed, Repowering Mobile.
It failed flash writing at 66%.Then I tried to full erase by using erase file it show the error like this...
Area2: 0x00010000-0x007FFFFF Erased, Time: 01:20
Area3: 0x02000000-0x027FFFFF Erased, Time: 01:22
Area4: 0x04000000-0x047FFFFF Erased, Time: 01:23
Erasing: 0x06000000-0x067FFFFF ...
Erasing Error: 10, at: 0x06000000-0x0601FFFF, 940207, Time: 00:00
Now How can I solve the problem ? Help me....
Old 01-15-2008, 17:28   #12 (permalink)
gsm st's Avatar
Member: 143007
Thanks Meter: 141
ufs result...
sir some time coming this masege cable problem, or try jaf version.1.98.44 my b solve youe problem..
Old 01-17-2008, 12:57   #13 (permalink)
Member: 63030
Thanks Meter: 8
I changed the cable but the result is same ,I think one of the flash ic is damsged but i don't now which is bad upper or lower ,anybody help...
Old 10-14-2008, 15:34   #14 (permalink)
Member: 386455
change uem and flash ic
Old 10-16-2008, 13:44   #15 (permalink)
dvsbbdd's Avatar
Member: 703284
Sonork: 0
Thanks Meter: 66
change flash ic 100% no uem resulte me
7610 flash problem!!!!!! jason_ting Nokia Hardware & Hardware Repair 4 07-07-2005 08:58
7610 flashing problems with griffin 2.0895 ????? PTR999 Griffin 5 06-24-2005 20:06
nokia 7610 flashing problem systemworm Nokia Digital Core Technology 4 ( DCT-4 ) 2 04-17-2005 03:59
Page generated in 0.33593 seconds with 9 queries
