7610 full factory defaults failed after flashing i have 7610 after flash full factory defaults failed.......can anyone give me the solution...... |
Try to erase in griffin and try to flash it latest version.... Good Luck..... |
are the phone can be in local mode? |
are the phone can be in local mode? if yes cek ur imei, if ur imei ???? u must ask to rpl first and write imei.. and try tu full factory default again |
hi br acay if not in local mode how to solve it? thnx |
first erase flash then flash it with latest version then write pm and post results |
after fleshing try manual formating |
first erase flash the latest version then write pm for jaf |
in a future plz post in the right section........ that is good for all of us |
sir,actually it is now started.......when i flashed it with the another flash file ....rh_5167pe605250.C2 as MCU & RH51PE605250.57 AS PPM file .....SIR IT STARTED & WORKING WELL BUT ITS LANGUAGE IS NOW CHINESE......& I HAVE DONE THE MANUALLY FORMAT BUT STILL IN SAME LANGUAGE .....SO GIVE ME THE SOLUTION..... |
full format this way 0x00000000-0x007FFFFF 0x02000000-0x027FFFFF 0x04000000-0x047FFFFF and then flash write good pm..ui ... |
when ever i flash my mobile allways i get error .....tx line failed or reconnect it most of handset i get tis erro?????????/ |
use ufs if u are not familiar with jaf |
Phone didn't answer with TX line high after UEM reset! Causes: 1. BSI line is not connected properly in connector -> Check cable, also for 3.3k resistor in serial with bsi line. 2.UEM damaged -> replace UEM. MCU ID: 0xCCCC Failed! Aborting! |
i wnt to work on jaf so dont say alternative use usf help me .....G Phone didn't answer with TX line high after UEM reset! Causes: 1. BSI line is not connected properly in connector -> Check cable, also for 3.3k resistor in serial with bsi line. 2.UEM damaged -> replace UEM. MCU ID: 0xCCCC Failed! Aborting! |
