Old 07-15-2007, 16:28   #1 (permalink)
Member: 142994
Thanks Meter: 57
7610 full factory defaults failed after flashing
i have 7610 after flash full factory defaults failed.......can anyone give me the solution......
Old 07-15-2007, 16:32   #2 (permalink)
Member: 192146
Thanks Meter: 44
Try to erase in griffin and try to flash it latest version....
Good Luck.....
Old 07-15-2007, 16:50   #3 (permalink)
acay's Avatar
Member: 197916
Thanks Meter: 156
are the phone can be in local mode?
Old 07-15-2007, 16:54   #4 (permalink)
acay's Avatar
Member: 197916
Thanks Meter: 156
if yes cek ur imei, if ur imei ???? u must ask to rpl first and write imei..
and try tu full factory default again
Old 07-15-2007, 17:16   #5 (permalink)
Member: 105689
hi br acay
if not in local mode how to solve it?
thnx
Old 07-15-2007, 21:02   #6 (permalink)
aryan_'s Avatar
Member: 256027
Thanks Meter: 52
first erase flash then flash it with latest version then write pm and post results
Old 07-15-2007, 21:15   #7 (permalink)
Member: 367928
Thanks Meter: 178
after fleshing try manual formating
Old 07-16-2007, 03:13   #8 (permalink)
zahed1978's Avatar
Member: 444785
Thanks Meter: 170
first erase flash the latest version then write pm for jaf
Old 07-16-2007, 03:50   #9 (permalink)
kashi4gul's Avatar
Member: 460762
Sonork: 100.1592082
Thanks Meter: 3,085
u have post in wrong section.........
in a future plz post in the right section........
that is good for all of us
Old 07-16-2007, 18:45   #10 (permalink)
Member: 142994
Thanks Meter: 57
sir,actually it is now started.......when i flashed it with the another flash file ....rh_5167pe605250.C2 as MCU & RH51PE605250.57 AS PPM file .....SIR IT STARTED & WORKING WELL BUT ITS LANGUAGE IS NOW CHINESE......& I HAVE DONE THE MANUALLY FORMAT BUT STILL IN SAME LANGUAGE .....SO GIVE ME THE SOLUTION.....
Old 07-16-2007, 23:23   #11 (permalink)
Member: 275451
Thanks Meter: 84
full format this way
0x00000000-0x007FFFFF
0x02000000-0x027FFFFF
0x04000000-0x047FFFFF
and then flash write good pm..ui ...
Old 07-17-2007, 11:52   #12 (permalink)
Member: 356389
when ever i flash my mobile allways i get error .....tx line failed or reconnect it most of handset i get tis erro?????????/
Old 07-18-2007, 00:31   #13 (permalink)
Member: 275451
Thanks Meter: 84
use ufs if u are not familiar with jaf
Old 07-20-2007, 11:29   #14 (permalink)
Member: 356389
Getting MCU ID
Phone didn't answer with TX line high after UEM reset!
Causes:
1. BSI line is not connected properly in connector -> Check cable, also for 3.3k resistor in serial with bsi line.
2.UEM damaged -> replace UEM.
MCU ID: 0xCCCC
Failed! Aborting!
Old 07-20-2007, 11:32   #15 (permalink)
Member: 356389
i wnt to work on jaf so dont say alternative use usf help me .....G
Causes:
MCU ID: 0xCCCC
Failed! Aborting!
2626 white Display blinking after full factory default by ufs. pradeepmishra Nokia Hardware & Hardware Repair 1 12-18-2008 18:32
6020 full factory defaults failed sinikrishna UFS2 + UFS3-Tornadoflasher 0 08-07-2008 08:36
6280 and 5500 set full factory defaults fail pordel Universalbox 1 04-26-2007 10:33
6233 restred after full factory default bna Nokia Base Band 5 ( BB-5 ) 0 11-23-2006 19:54
nokia 6260 full factory defaults failed mujib Twisterflasher 1 07-29-2005 11:29
Page generated in 0.37716 seconds with 8 queries
