04-07-2007, 12:32 | #1 (permalink) |
Freak Poster Join Date: May 2005 Age: 45
Member: 143156 Status: Offline Thanks Meter: 95 | 7610 hang pls help me phone after nokia is hang Getting MCU ID MCU ID: 0x1081 FLASH ID0: EC00FEDD -> ST Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10 FLASH ID1: EC00FEEE -> ST Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 10 FLASH ID2: EC00FA22 -> ST Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 10 FLASH ID3: 00000100 -> NOT USED Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0 First 16 bytes: C6 00 00 EA 75 01 00 EA 78 01 00 EA 7B 01 00 EA Checking RAM for ALGO... Algo is ready... Checking FAID calculation... P-key nokia module version 01.00 Done! Phone Restarted... FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-51\RH51_52_67_68PE706420.C1 PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-51\RH51PE706420.03 CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Languages in ppm: English,Arabic,French (Arabic) MCU: C:\Program Files\Nokia\Phoenix\Products\RH-51\RH51_52_67_68PE706420.C1 Booting phone... MCU ID: 0x1081 BOOT file: C:\Program Files\ODEON\JAF\Flash\w3_2nd.fia Loader version: 04.3D.00 -> Revision: 0007 Boot size is 0x1090 Boot is ready... FLASH ID0: EC00FEDD -> ST Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10 FLASH ID1: EC00FEEE -> ST Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 10 FLASH ID2: EC00FA22 -> ST Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 10 FLASH ID3: 00000100 -> NOT USED Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0 First 16 bytes: C6 00 00 EA 75 01 00 EA 78 01 00 EA 7B 01 00 EA Flash ID is 0xDDFE00EC Flash loader is C:\Program Files\ODEON\JAF\Flash\w3_amd.fia Loader version: 04.3D.00 -> Revision: 0007 Loader size is 0x7E70; Loader chk: 75 Error Loading loader! Backing up PM Field 208 as RPL... Setting local mode... Reading IMEI... Reading IMEI data... Building RPL backup file... C:\Program Files\ODEON\JAF\ProgData\351111101489938_imei_back up_142974.rpl Done! Backup imei OK! MCU: C:\Program Files\Nokia\Phoenix\Products\RH-51\RH51_52_67_68PE706420.C1 Booting phone... MCU ID: 0x1081 BOOT file: C:\Program Files\ODEON\JAF\Flash\w3_2nd.fia Loader version: 04.3D.00 -> Revision: 0007 Boot size is 0x1090 Boot is ready... FLASH ID0: EC00FEDD -> ST Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10 FLASH ID1: EC00FEEE -> ST Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 10 FLASH ID2: EC00FA22 -> ST Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 10 FLASH ID3: 00000100 -> NOT USED Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0 First 16 bytes: C6 00 00 EA 75 01 00 EA 78 01 00 EA 7B 01 00 EA Flash ID is 0xDDFE00EC Flash loader is C:\Program Files\ODEON\JAF\Flash\w3_amd.fia Loader version: 04.3D.00 -> Revision: 0007 Loader size is 0x7E70; Loader chk: 75 Loader is ready... P-key nokia module version 01.00 MSID: 84A2190F7554D6A8FC6E944BDA MSID decoded: 3E4EBAF7009BCBD9A9000000 FAID: 6C08941E66919F1362423923 Operation took 0 minutes 23 seconds... Erasing... Found 4 interval(s) to erase Erasing area: 00000000 - 0000FFFF... Erasing area: 00010000 - 00FFFFFF... Erasing area: 02000000 - 0287FFFF... Erasing area: 02FC0000 - 02FEFFFF... Operation took 2 minutes 52 seconds... Writing... Perm. Data Restore OK Operation took 3 minutes 18 seconds... Restarting MCU... PPM: C:\Program Files\Nokia\Phoenix\Products\RH-51\RH51PE706420.03 Booting phone... MCU ID: 0x1081 BOOT file: C:\Program Files\ODEON\JAF\Flash\w3_2nd.fia Loader version: 04.3D.00 -> Revision: 0007 Boot size is 0x1090 Boot is ready... FLASH ID0: EC00FEDD -> ST Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10 FLASH ID1: EC00FEEE -> ST Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 10 FLASH ID2: EC00FA22 -> ST Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 10 FLASH ID3: 00000100 -> NOT USED Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0 First 16 bytes: C6 00 00 EA 75 01 00 EA 78 01 00 EA 7B 01 00 EA Flash ID is 0xDDFE00EC Flash loader is C:\Program Files\ODEON\JAF\Flash\w3_amd.fia Loader version: 04.3D.00 -> Revision: 0007 Loader size is 0x7E70; Loader chk: 75 Loader is ready... P-key nokia module version 01.00 MSID: 84755ADCE07CDCD42C4F8AC20C MSID decoded: 3E4EBAF7009BCBD9AA000000 FAID: A7E4E97D256E6A2DF4104BEE Operation took 0 minutes 23 seconds... Erasing PPM... Found 2 interval(s) to erase Erasing area: 00000000 - 0000FFFF... Erasing area: 02A00000 - 02CAFFFF... Operation took 0 minutes 19 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 23 seconds... Restarting MCU... Flashing Done! Operation took 7 minutes 46 seconds... After flash processing... Waiting for phone to boot... Reading... Failed! Aborting!...MCUVER this factory set After flash processing... Waiting for phone to boot... Reading... Phone type: RH-51, Software version: 7.0642.0 IMEI: 351111101489938 Product Code: 0514537 Resetting PPC... Setting FULL FACTORY......Setting test mode... Setting FULL FACTORY... Operation took 1 minutes 29 seconds... Done! Done! Powering the phone... Unlocking... IMEI: 351111101489938 ASIC: 5 SW version: 7.0642.0 Checking locks... Block 1: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Done! DCT4 unlock counter: 139 Setting local mode... Reading imei... IMEI/ESN: 351111101489938 Reseting warranty data... Reseting LifeTimer... Lifetime data not found!!! Done! this format Init phone communication... Setting test mode... Detecting File System... No file system detected... please help me Last edited by gsm4sp; 04-07-2007 at 12:42. |
06-26-2007, 20:43 | #5 (permalink) |
No Life Poster Join Date: Feb 2005 Location: HOME OF PEACE
Member: 113732 Status: Offline Thanks Meter: 90 | Pls always search before posting. THE ANSWER is every nokia site. Heat the CPU and fullflash and format 3+*+send together then ON the phone till formatting starts. If this did not work then search the forum. SEARCH NEXT TIME BEFORE POSTING. |
12-28-2007, 11:10 | #6 (permalink) | |
No Life Poster Join Date: Jan 2007 Location: udaipur, I N D I A Age: 37
Member: 422762 Status: Offline Sonork: 100.1593904 Thanks Meter: 973 | Quote:
N70 hanging at "nokia" pls help me pls... | WinD_VteC | Nokia Hardware & Hardware Repair | 3 | 01-12-2008 14:45 |
6680 White Display Hang Pls Help Me | gsm_khorshed | Nokia Hardware & Hardware Repair | 2 | 11-03-2007 10:15 |
good rpl for 7610 pls help me!! | lemor | Twisterflasher | 9 | 12-10-2005 14:40 |
Pls help me my siemens c-35 keypad Hang pls help me | varma raj | x1x to x45/x50 | 1 | 06-17-2003 10:50 |
