05-25-2007, 17:58 | #1 (permalink) |
Freak Poster Join Date: Jan 2004 Age: 45
Member: 49428 Status: Offline Thanks Meter: 45 | -= 7610 help please (looking for alternate points)... I am repairing a 7610 "Phone start-up failure. Contact Retailer...." I removed the IC in attached pic but, I may have lifted a few points off during the removal and was wondering if any of you may know where the alternate points are ... I have attached a pic with the points in question circled in red. I want to find the alternate points to retrace the SIM connectors to see if this would fix the failure listed above... Thanks in advance for all of your help! -Kabs Last edited by KaBLooMz; 05-25-2007 at 18:13. Reason: attached pic |
05-25-2007, 21:32 | #4 (permalink) |
Junior Member Join Date: Sep 2005 Location: Egypt Age: 46
Member: 183971 Status: Offline Thanks Meter: 0 | Man your phone problem is not with the's IC maybe it's software just erase ur phone then flash it full flash and format user area if the problem still change ur IC flash |
05-26-2007, 15:55 | #5 (permalink) |
Member: 49428 Status: Offline Thanks Meter: 45 | Actually, I wrote down the wrong message. It said "Insert Sim" even when sim is inserted. Lolz, I have 2 7610's I am working on at the same time. One says "Insert Sim", this is the one where I need the points retrace. The other one with the contact retailer, i think my only option is to replace UEM (for which I don't think I can do yet). -=-=-=-=-=-=- Again the question is, does anyone know the alternate point's in the attached diagram. Thanks! -=-=-=-=-=-=- -Kabs |
05-27-2007, 08:18 | #7 (permalink) |
Registered User Join Date: Apr 2007
Member: 483748 Status: Offline Thanks Meter: 47 | U Donnot Need To Replace Uem Just Check Which Prints Are Missing.then Take Out Connection From Uem With The Help Of Jumper Wire.( Condition If Input Track Are Damaged ). Try To Change Boot Ic. ( Contact Retailer ). |
05-28-2007, 17:36 | #8 (permalink) |
Member: 49428 Status: Offline Thanks Meter: 45 | @xtremeburaq so do u know the points I need to jumper off of the UEM? How do I know what connections to use as alternate points. I don't have boot IC to change... I just remove the IC and follow the jumpers to similar diagram. kabs |
06-05-2007, 03:37 | #10 (permalink) |
Junior Member Join Date: Jun 2007
Member: 521484 Status: Offline Thanks Meter: 0 | You should be able to find them with a voltmeter set to "buzz thru" (buzz for < 100 ohm resistance). You can set one lead to the track in question and poke around other vias and connections until you get a buzz meaning you found a short and anything along this track/connection is an alternative connection. |
06-05-2007, 03:40 | #11 (permalink) |
Member: 521484 Status: Offline Thanks Meter: 0 | by the way have you been able to figure out how to fix the "insert sim card" problem even tho a sim card is inserted? I have the same problem ever since I dropped the phone into water. Also would you know how to retrieve info from internal memory without a sim card present? I'm trying to either fix the phone or just to power it on and get all the stuff out of the memory so I can save my contact list, etc. |
ned help to look for LG KE500 cable from gpg cable set is only #XXX and don't which | mymiela0419 | FuriousGold | 1 | 02-28-2010 23:54 |
Help im looking for a job...... | HESAM24 | Job Opportunities / Vacancies | 0 | 11-26-2008 05:05 |
[w800i]Need help with search for alternate joystick points. Photo included! | conspiracy | Sony Ericsson Hardware Repair | 5 | 05-18-2008 15:00 |
help!i looking for BE5 2M flash | gsmcable | Alcatel & TCL Old Models | 0 | 07-12-2002 04:23 |
