Old 02-15-2005, 20:09   #1 (permalink)
Member: 43545
Thanks Meter: 7
7610 insert simcard
hi mates
ihave a nokia 7610 they shows insert simcard i resold simconnector ....any hint pl ...thanks Or where i found symatic dig....of 7610 thanks again
The Following User Says Thank You to tanmay For This Useful Post:
Old 02-15-2005, 21:27   #2 (permalink)
deesperado's Avatar
Member: 94306
Thanks Meter: 6
change uem and it will work fine
B.R.
desperado
Old 02-19-2005, 09:57   #3 (permalink)
desmond2727's Avatar
Member: 58704
Sonork: 100.1618753
Thanks Meter: 43
Originally Posted by tanmay
hi mates
Hi mate that is sim ic cystal one near by sim conector problem..
If got any problem u can pm me..
The Following User Says Thank You to desmond2727 For This Useful Post:
Old 02-21-2005, 23:02   #4 (permalink)
Member: 51618
Arrow
here's your requist :
resold that small ic..........
Old 02-21-2005, 23:03   #5 (permalink)
Member: 51618
i'm so sorry
in some cases u should change it
Old 02-27-2005, 18:45   #6 (permalink)
pazeth™'s Avatar
Member: 74519
Thanks Meter: 79
7610 Insert SIM Card
How to fix?, sometime we can make jamper with a very small cable
The Following User Says Thank You to pazeth™ For This Useful Post:
Old 03-08-2005, 19:06   #7 (permalink)
Member: 43545
Thanks Meter: 7
Thanks
ACTMOBILE I CHANGE R31O .....& AFTER THAT MY MOBILE IS WORKING ....THANKS A LOT
Old 03-09-2005, 14:33   #8 (permalink)
Registered User
MAGDY2's Avatar
Member: 49677
Thanks Meter: 53
good man many thx i will try it
Old 04-08-2005, 06:50   #9 (permalink)
RAYGUN's Avatar
Member: 81289
Thanks Meter: 236
Thanks
good job my men i try it to changed R310 and workit
Old 04-10-2005, 17:24   #10 (permalink)
Member: 43545
Thanks Meter: 7
dears
if ur r310 is damaged (7610) u change r310 wid 8310 OR 6510 its working fine ....enjoy
Old 08-26-2005, 11:05   #11 (permalink)
opo
opo's Avatar
Member: 16350
Sonork: 110823
Thanks Meter: 42
so that means also making wires(like for 8310) will work too if @tanmay is write
Old 09-15-2005, 13:55   #12 (permalink)
TONYTONY's Avatar
Member: 35975
Thanks Meter: 19
opo can u pls tell me again how to make wires for 8310. If u post a pic it will be very very good.
thanks man
tonytony
Old 09-16-2005, 08:10   #13 (permalink)
opo
opo's Avatar
Member: 16350
Sonork: 110823
Thanks Meter: 42
if u take down the litle BGA IC u have one matrix like this
123
456
78
The numbers should be the baals beneth the IC
U have to solder 1-3,4-6,7-8 and all works like a charm
Good luck
Old 09-16-2005, 08:56   #14 (permalink)
TONYTONY's Avatar
Member: 35975
Thanks Meter: 19
Thanks opo it really works. Thanks mate...
tonytony
Old 09-23-2005, 10:58   #15 (permalink)
Crazy Poster
Member: 183379
Thanks Meter: 10
Thumbs up 3200 insert sim
my cases is(3200) but after i try change the sim crystal ic(6510) n its also work too....job done
7610 after fix insert simcard pazeth™ Nokia Hardware & Hardware Repair 17 08-13-2009 19:04
nokia 6260- simcard regected,insert simcard obioha powerflasher 5 09-06-2006 08:49
7610 restart if insert simcard bengkel_hp Nokia Hardware & Hardware Repair 6 04-01-2005 20:32
1100 insert simcard with simcard inside MichieMax Griffin 11 07-09-2004 23:36
3310 Insert simcard with simcard in side uwenk98 Nokia Hardware & Hardware Repair 8 04-25-2004 14:33
Page generated in 0.20535 seconds with 10 queries
