Old 12-18-2008, 05:48   #1 (permalink)
Member: 340774
Thanks Meter: 164
n73 showing shorting on batt. conector
i ve n73 and it showing shorting on its batt connector.. it uses too much batt. power and only works for 3 hours
Old 12-18-2008, 07:51   #2 (permalink)
venuno's Avatar
Member: 532761
Sonork: 100-1592994
Thanks Meter: 1,104
format phone possible virus then
scan memory card
Old 12-18-2008, 07:55   #3 (permalink)
Member: 286908
Thanks Meter: 81
check here
http://forum.gsmhosting.com/vbb/showthread.php?t=556022
Old 12-18-2008, 08:03   #4 (permalink)
NAVEED74's Avatar
Member: 188574
Sonork: 100.1590742
Thanks Meter: 751
Solution already posted before in this forum.
here is the right way to check short for N73. Thanks to whom he posted before.
[FONT=Calibri]check shoting in nokia n-73.....[/FONT]
1....remove this COIL mark in (1) if u want to check the shoting of pf .......remove the coil and ur shoting is gone then there is shoting in ur pf .......
2..remove this coil mark in (2)..if u want to check rf ic is short because rf ic also got +b volt from battery....
3..remove this resistance mark in (3)..if u want to check blutooth ic is short because bluetooth ic also got +b volt from battery....
4..remove the resistance mark in (4) ..if u want to check irda module ... because irda module got +b from batery....
5..remove light ic mark in (5)..if u want to check the light ic is short....
6..remove ic n3500 mark in (6)....it is for memory card ....this ic make volt for memory card..........
7..remove ringer ic mark in (7)..if u want to check shoting remove it and check if shoting is gone replace it because ringer ic also got +b volt from battery....
8..remove this ic mark in (8)..if u want to check the shoring cause flash light driver ic n1471 ....because this ic got +b from batery....
9..remove this ic n6519 mark in (9).. this ic make volt for front camera (1.5v) remove this if u want to check the shoring cause by this ic....because this ic got +b from batery......
10..remove this ic n7542 mark in (10).. this ic make volt for front camera (2.8v) remove this if u want to check the shoring cause by this ic....because this ic got +b from batery......
11..remove smps ic n6515 mark in (11)..if u want to check smps ic n6515.. ..this ic make v corea for omap ic and rap remove and for ape memory remove this to check shoting is gone or not.....because this ic got +b from batery......
12..remove this ic n9006 mark in (12).. this ic make volt for main camera (1.5v) remove this if u want to check the shorting cause by this ic....because this ic got +b from batery......
13..remove this ic n6517 mark in (13).. this ic make volt for main camera (1.5v) remove this if u want to check the shorting cause by this ic....because this ic got +b from batery......
14..remove this ic n6518 mark in (14).. this ic make volt for main camera (1.8v) remove this if u want to check the shorting cause by this ic....because this ic got +b from batery......
15..remove this ic n6516 mark in (15).. this ic for controling ic for main camera remove this if u want to check the shorting cause by this ic....because this ic got +b from batery......
16..remove this ic n6513 mark in (16).. this ic make volt for main camera (2.8v) remove this if u want to check the shorting cause by this ic....because this ic got +b from batery......
17..remove this ic n6508 mark in (17).. this ic make vio supply... remove this if u want to check the shorting cause by this ic ...because this ic got +b from batery......
18..remove this ic v6519 mark in (18).. this ic is for leds .....remove this if u want to check the shorting cause by this ic ...because this ic got +b from batery......
19...remove this ic v6507 mark in (18).. this ic is for leds .....remove this if u want to check the shorting cause by this ic ...because this ic got +b from batery......
20...at end remove bety and avilma power ic to check shoting is gone or not......
all the component which are mark in pink colur these all are coils and resistance these are place in series and +b of batery is gone throw them so if u remove the coil and resistance u not have to remove ic to check the shorting in pcb it save time and ur ic ....
Old 12-18-2008, 08:12   #5 (permalink)
metro2mobile's Avatar
Member: 515972
Thanks Meter: 526
all ready postd
in Easy way to check shorting in bb5 phones
all shorting in first page brother
Old 05-06-2009, 19:34   #6 (permalink)
Member: 943057
Thanks Meter: 14
nice solutions,, thanks,,,,,,,,,,,
br
Kg195 batt conector ZAHID338 LG Hardware Repair 1 05-14-2009 08:43
n70 batt conector ok dc input terminel short heip plsssss gsmking2006 Nokia Hardware & Hardware Repair 3 03-18-2009 19:42
n70 batt conector short any idea plsssssss gsmking2006 Nokia Hardware & Hardware Repair 3 03-13-2009 08:11
2100 showing short but set is on jassgill25 Nokia Hardware & Hardware Repair 7 12-17-2006 07:03
2100 showing short but set is on jassgill25 Nokia Hardware & Hardware Repair 0 12-09-2006 05:15
Page generated in 0.25942 seconds with 11 queries
