07-06-2008, 16:20 | #1 (permalink) |
No Life Poster Join Date: Mar 2008 Location: sri lanka Age: 35
Member: 716976 Status: Offline Sonork: 100.1674578 Thanks Meter: 108 | 7610 menu not worek |
07-06-2008, 22:49 | #5 (permalink) |
Freak Poster Join Date: Jun 2008 Location: Heaven
Member: 801083 Status: Offline Thanks Meter: 99 | 7610 keypad menu not funktion Step by step solution: software solution : -- write pm file ---- hardware solution: 1. Chek keypad board ---- clear or change. 2. Chek track from keypad board to conector, if cut ---- jumper or change kaypad board. 3. chek track from conector to kepad IC, if cut --- jumper, replace or change keypad IC. 4. chek keypad IC -- clear, replace or change keypad ic 5. Chec the track from keypad ic to upp, if cut --- jumper , reheat upp, reball upp, change upp (if you change upp, you have to flash ur fone again) good luck |
The Following User Says Thank You to AdickAsia For This Useful Post: |
D900 eyar piss not worek....... | farshad2009 | Samsung Hardware Repair | 3 | 04-14-2011 07:57 |
k810i key not worek | farshad2009 | Sony Ericsson Hardware Repair | 7 | 01-06-2010 07:39 |
Nokia 7610 Menu & Camera Key not working | Saleemsmj | Nokia Hardware & Hardware Repair | 1 | 10-15-2009 10:37 |
7610 menu key not work | coolmax | WD2 & APE (Symbian Phones) | 13 | 06-30-2009 04:25 |
N70 bluetooth not worek | farshad2009 | Nokia Hardware & Hardware Repair | 6 | 11-08-2008 14:09 |
